 Rank: Pro  Groups: Registered
Joined: 23/09/2009 Posts: 138 Points: 422 Location: Surrey
Here's a few pics of my Tamiya Kawasaki H2R kit which is still in progress. I'm going for a highly detailed model, using both the Hobby Design and Top Studio detail kits. The TS set has turned forks and a better rear brake disc. The HD set has a lot of stuff that the TS set doesn't. It's front discs are better than the TS set, and it includes a chain as well. There's also add scratch built parts, various bolts and rivets added, Studio 27 carbon decals and Zero paints set. The horrible cross head screws Tamiya insist on using will all be replaced or hidden. The Zero paints candy green on the frame is stunning. Untitled by Mark Wakelin, on Flickr The fairing is held on with magnets. Really easy to do using 2mm x 1mm disc magnets from eBay. Untitled by Mark Wakelin, on Flickr The ABS pump was missing from the kit, so I scratch built one using photos on the 'net as a reference. Untitled by Mark Wakelin, on Flickr Missing rear brake pipes added. Untitled by Mark Wakelin, on Flickr The Hobby Design chain compared to the kit part. I really like the Hobby Design chains. Not too difficult to assemble, and look amazing. Easier that the Tamiya RC166 chain, and a lot easier than the Top Studio chains. IMG_4787 by Mark Wakelin, on Flickr In close-up IMG_4815 by Mark Wakelin, on Flickr A more or less completed engine. Untitled by Mark Wakelin, on Flickr The Hobby Design front disc, compared to the kit part. Thee are about 40 parts in the front discs if I recall. Untitled by Mark Wakelin, on Flickr Front fairing with Studio 27 carbon decals. These go on a dream as long as you apply a bit of heat with a hair dryer on low. Untitled by Mark Wakelin, on Flickr Rear brake pipe that goes over the swing arm. Untitled by Mark Wakelin, on Flickr Finally, this is more or less the state of play at the moment. Untitled by Mark Wakelin, on Flickr Feel free to ask questions, comment or critique.
 This looks amazing and I WILL be following ! That green looks fantastic and very Kawasaki The difference in the two chains is like day and night. Well done so far Regards Gray
Thanks Gray. Still making slow but steady progress. The rear brake pipe is finally fitted. This took much longer than anticipated. The cable fixing points were too thick to allow the swing arm cover to fit properly, so out with the clippers, files and knives, and eventually I beat it into submission. The ABS sensor cable is there as well. I didn't connect the pipes to the pipes from the ABS pump in the end, as they are hidden by the seat frame and can't be seen at all. It was going to be very difficult to get right as well, so I stopped them where the seat frame started. Untitled by Mark Wakelin, on Flickr Now I can get the back wheel on as well. This didn't want to go on either. There seemed to be a step inside the axle hole which was just stopping the wheel going on. The axle is exactly 4mm, but I didn't have a 4mm drill bit. We don't have DIY shops in Hong Kong either, so I ended up sanding it out with some rolled up sandpaper. The outer hub, silver grey coloured with the silver raised lines, was also a pain. The instructions say to paint it gunmetal, and them put a decal on for the raised silver lines. The gunmetal was way too dark and the decal went all skew wiff! So, it got stripped, repainted silver grey. A mix of light grey and flat aluminium. The raised lines were added by hand. Came out much better second time. Then it wouldn't sit on the sprocket properly. The spigot broke while I was trimming it, and it took a bit of scraping and fettling to get it to fit even then. What a pain in the neck....... That was most of the weekend gone!! Untitled by Mark Wakelin, on Flickr Now on to the front forks. These went better (at last..... something went right!) All superglued together, and a drill through the axle holes to ensure everything is aligned. The fork bottoms are cut from the kit forks. I hole drilled, then they can be glued on to the ally aftermarket forks. Now it's assembled, I can start super-detailing the forks and calipers. Mainly adding/replacing bolts, replacing the brake pipe unions, etc. I'm really pleased with the black nitride finish to the fork sliders. I've since learnt that it's actually called a diamond like carbon finish. Apparently it's virtually black in real life. However, the gloss varnish with the bit of black in it, over the polished ally gives a great effect. High gloss and metallic, but not at all like a metallic paint. Quite different from the semi-gloss black of the fork bottoms. Untitled by Mark Wakelin, on Flickr So, what's next. Well, the exhausts are in the process of being painted. The rad is more or less finished, but needs work on the pipework. The tank and fairing parts are being painted.
Fabulous work Mark, love the detail..... Regards Alan
Joined: 13/02/2011 Posts: 2,239 Points: 6,837 Location: East Sussex
Great work Mark and a great presentation. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks guys, I’m really enjoying this build.
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,866 Points: 20,915 Location: Northamptonshire, England
Great work Mark, loving all the attention to detail. Mark Regards Markwarren (Mark) Admin
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,060 Points: 15,326 Location: ipswich
Amazing work there Mark. It looks as big as the DeAg kits. This is going to be a real showpiece.
Looking very good. I also like the method of supporting the build. Congrats on your "Blue" medal for starting/running a build diary. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks Derek. Hadn’t noticed the medal The motojig is brilliant, if expensive. Worth the money if you’re super-detailing a bike though. However, it’d be a lot cheaper to make your own if you have a drilling and milling machine.
Mark wrote:Thanks Derek. Hadn’t noticed the medal The motojig is brilliant, if expensive. Worth the money if you’re super-detailing a bike though. However, it’d be a lot cheaper to make your own if you have a drilling and milling machine. Congrats on your medal You're not kidding about how expensive that jig is (£130!!!) However, if i could get one to fit the M1 .....
A bit more progress. Heat staining on the exhausts. This was done with Alclad hot metals red and blue, and the Tamiya weather powder burnt red, which is more of a sepia. Untitled by Mark Wakelin, on Flickr Exhaust springs, which were from the Top Studio detail set. Fiddly in the extreme! Untitled by Mark Wakelin, on Flickr Fitted to the bike. Untitled by Mark Wakelin, on Flickr The tank and front mud guard are painted in Zero gloss black with a coat of clear on top. Looking good, even if I say it myself! Untitled by Mark Wakelin, on Flickr Then finished with a metalising powder to give the black chrome effect. This was part of the Zero paints matched set from Hiroboy. Untitled by Mark Wakelin, on Flickr Untitled by Mark Wakelin, on Flickr I just hope I can get the other body panels finished to the same standard!
Excellent work Mark, those exhaust pipes look spot on. Mark Regards Markwarren (Mark) Admin
 The tank and front fender look the dogs
Thanks for the comments guys. I've noticed that the tank and front fender look different in the two photos. It's a trick of the light. They look the same in real life. Mind, the black chrome does look different depending on how the light catches it.
I've been making slow progress, and generally filling about with bits here and there, or that's what it feels like. Radiator plumbed in, hose clamp added, and bolt head added to the top of the rad. Untitled by Mark Wakelin, on Flickr Started work on the front brake lines. I'm making these from 5A fuse wire. Once they are to size and shape, I slip silver brained hose over them, paint them with diluted Krystal Klear to stop any fraying, then they'll get glued in place. Still a work in progress. Untitled by Mark Wakelin, on Flickr Handle bars are still in progress, but getting there. Numerous colours on these. I sprayed the base satin black, then hand painted the rest. The green fork tops are sprayed of course as they are separate parts. There was etched replacements for these in the HD detail set. However, they are made from layers of etched parts, and it would be a devil hiding the edges. So I decided to use the kit parts. There are a couple of tiny rivets from the detail set in place. There are also some really tiny etched rings to go on top of the 4 pips. Not sure if my eyes are hands are up to adding these, they are rings, about 1mm diameter, and no spares for the carpet monster. I still have the clutch and brake reservoirs to paint and add. Untitled by Mark Wakelin, on Flickr Front fairing glossed up nicely. The two winglets still need to be glued in place. There are also a couple of etched bolt heads to go on. Untitled by Mark Wakelin, on Flickr Seat frame in place. This is actually fitted with the Tamiya screws, but they are deep enough to be invisible. I need to check references to see what bolt heads need to be added. This was a devil to fit, and I scratched the candy green, annoyingly. Hopefully that will touch up with a brush OK. Untitled by Mark Wakelin, on Flickr Finally for now, the handle bars in place. I think these will stay there as I can add everything else while they are in position. Untitled by Mark Wakelin, on Flickr Like I said, a bit of a jumpy update, but there is a light at the end of the tunnel now. Finish the front forks and get the brakes plumbed in, finish the last few details, brake reservoirs, gear change linkage, side stand, and so on, then the bodywork to fit. Decals are more of less done, and the bodywork is more or less painted.
Very impressive stuff there Mark. It's really looking way bigger than it really is.
Roy.
Top notch work Mark, looks simply fabulous.... Regards Alan
Excellent work Mark. Mark Regards Markwarren (Mark) Admin
