 So, have finally received Pack 9. Massive box for what could probably have fit in a jiffy bag, but hey, better safe than sorry In this pack, we get: Stage 32) The oil pump, cover and coupling Stage 33) The clutch bell and plates Stage 34) Final clutch parts Stage 35) Coolant hose, pipes and starter motor
Stage 32. Assembly of the oil pump and cover, and attaching the coupling to the engine block. The two halves of the oil pump are pressed together and attached to the block. The coupling mounts onto the block with the slots provided. CaptnBirdseye attached the following image(s):
Stage 33 The clutch bell and plates come together: The clutch plates sit onto the spline in the clutch bell by aligning the notches. CaptnBirdseye attached the following image(s):
Stage 34 Assembly of the final clutch parts: The box sits in the recess on the block, aligning the two pins. The tube is then attached from the pin on the block to the front pin on the box. The final parts that make up the clutch is then attached, and sits in the engine block with the two locating pins. CaptnBirdseye attached the following image(s):
Stage 35 Fitting the coolant hose, pipe and starter motor: The coolant pipe is inserted into the slots on the cylinder head cover, with the hose pushed onto the end of it. Once the starter motor is assembled, it is attached to the engine using the two pins near the clutch assembly. This completes stage 9 CaptnBirdseye attached the following image(s):
 All looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Coming along nicely and a good way to do the build diary. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
 Thanks for looking in guys, much appreciated
Looks great Gray, beautiful work..... Regards Alan
Thanks Alan, appreciated
Just catching up on your build. Certainly coming together very nicely, great work. Mark Regards Markwarren (Mark) Admin
Just caught up with this Gray. Looking very nice. You're doing a cracking job! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Mark, Phil, thanks for looking in and your comments. Always welcome
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,192 Points: 15,725 Location: ipswich
I must have missed your last update. It's looking fantastic. Keep it coming.
Roy.
Thanks for looking in, Roy Well, I’ve had a right mare with Stage 38! I managed to split one of the plastic pipes, and could I get one anywhere? In the end I had to resort to asking c/s if they could send me replacements. Thankfully, they did! I know they get a bad press sometimes, but I’d just like to say a huge thank you to those guys Next stages to follow.....
Pack 10In this pack, we see construction of the manifolds and throttle bodies, intake ducts, hoses, gaskets and rear shock absorber. Stage 36 The Manifolds and Throttle bodies. The manifolds and throttle bodies are assembled by just push-fitting the parts together. These are then attached into the holes in the engine block, making sure the holes are outermost. The throttle return rod now fits to the throttle bodies, with the two pins fitting into the fore-mentioned outer holes. This completes stage 36 CaptnBirdseye attached the following image(s):
Stage 37 The Intake ducts. The two support rods are attached to the two side covers, noting the orientation. Fit the two intake ducts to the side covers. Retrieving the airbox from Stage 22, the ducts sit inside onto the four posts. The airbox cover then sits on top, and are locked together with the hooks over the pins. This completes stage 37 CaptnBirdseye attached the following image(s):
Stage 38 Hoses and Gaskets. This was my nemesis stage  . The two thicker tubes are fitted to the 'A' and 'B' couplings. That part went ok. However, when trying to fit the hoses to their mounting points on the engine, one of the pipes split. I had tried widening the pipe with a tooth pick, finally resorting to putting it in hot water hoping to expand the pipe. No joy, it split while fitting! Because they have to be cut to a precise 45mm, cutting it and starting again meant the pipe was now too short. I tried various modelling supplies stores, but no joy. In the end i just rang Customer services, and bless'em they sent me one out a couple of weeks later  . So, the larger pipes were installed in place, but i had another issue when fitting the two smaller pipes. The two couplings would not mount into the respective holes on the engine block. I resorted to increasing the size of the holes and securing in place with a spot of superglue  . At least the two gaskets fitted easily enough This completes stage 38 CaptnBirdseye attached the following image(s):
Another great update. It looks like a really detailed kit. Keep it coming.
Stage 39. The Rear shock Absorber. The shock absorber body is fitted into the spring. The rod is inserted down through the spring so that the 'window' aligns with the screw holes. Insert a screw into the shock absorber body to secure the shaft, but still allows the spring to compress. Mount the shock absorber assembly to the engine and secure with the screw provided, again allowing for movement. This completes stage 39 and Pack 10 CaptnBirdseye attached the following image(s):
