2.3x6mm and 4mm self tapping screws Options
ronald305
#1 Posted : 05 November 2019 18:08:49
hello there
has anyone run out of the 2.3X6mm self tapping screws also how can you tell the difference between the two size screws 4mm and the 6mm I do not want to use the wrong screws by mistake thank you
Ronald
Charlie Dude
#2 Posted : 05 November 2019 18:28:37
Rank: Amateur Level 1
The 6mm screws are 1/4 inch long and you'll have an abundance of them, they get used a lot.
Here's a conversion calculator: https://www.towerhobbies.com/help/convcalcs.html
This page was generated in 0.083 seconds.
