Projector still showing a bright circle Options
shunte
#1 Posted : 05 November 2019 16:38:17
I've had a replacement for the projector board from issue 27 as once built the projector wouldn't work, I have replaced the projector board but I still just get a white circle with no projection, has anyone else had this and managed to find a fix? It worked fine when tested before finalizing the build.
#2 Posted : 05 November 2019 23:44:26
Check the cables in the main board located in the dome, particularly the mic and camera sockets.
R2D2Nut
#3 Posted : 06 November 2019 12:34:21
Also, it can sometimes take a second or two for the image to appear.
shunte
#4 Posted : 06 November 2019 13:49:24
Thanks, I have checked all the connections in the head, disconnected and reconnected, can't remember which one the mic is, the camera is a ribbon connector and connected and working fine. Still no luck with the projector though
semaj
#5 Posted : 15 February 2020 01:39:25
A very common issue for this is the ribbon cable from the screen to the main projector board becoming dislodged during transit. Where the cable attaches into the socket on the board, very carefully flick it open (look for vids on youtube how to disconnect a ribbon cable) gently pop out the ribbon and re seat it again in the socket, ensure it is fully located and close the locking bar back down. This solved many of the problems other people had
Building:
Complete:
ir3an
#6 Posted : 25 February 2020 02:40:37
I am also amongst the many that have a faulty projector. Having tried all the ideas presented in this and other threads, I ordered a new one. They claim about 3 weeks but it could be months. My question is, can I finish the model and still be able to replace the projector when it comes or should I put a hold on the assembly once I get to the installation.
This is a quick build and I could be ready within a few days.
Thanks in advance for advice.
Iran Ausley
#7 Posted : 25 February 2020 21:00:36
Iran Ausley
I would certainly hold back on finishing the dome section where the projector is placed. Fitting a new one would entail dismantling some of the parts if you choose to complete it. Personally I would refrain from handling the main board too much, in case any damage is caused by unplugging cables that are attached to it, but that would be your decision.
This page was generated in 0.170 seconds.
