Footrope supports Options
BoatBetty
#1 Posted : 01 November 2019 23:01:57
Rank: Amateur Level 2
After a bit of advice - I'm trying to do the 6 footrope supports on the main yard but the copper just keeps breaking as I twist it and I am fast running out of copper length. Any tips?
#2 Posted : 01 November 2019 23:37:05
You may find information on this page useful. I didn't like the look of the brass wired ones so decided to make my own.... Hope it helps....
https://forum.model-spac...ts&t=5013&p=155
6649mgk
#3 Posted : 02 November 2019 00:08:08
Rank: Amateur Level 1
I had the same problem. You can buy copper wire from any crafting website and it will last you during your build. I make sure mine has been in the airing cupboard for a couple of hours before use.
Marl
#4 Posted : 02 November 2019 07:35:02
BigGrin Another way of doing it is to run the copper wire through a flame till it gets cherry red and let it cool this softens the wire so it's easier to twist Cool
Hope this helps
Martyn
BoatBetty
#5 Posted : 02 November 2019 10:40:28
You guys are ace! I will try these tips and also invest in a reel of copper wiring to last me.
It really was a sticking point and the reason I haven't done any of my build in two months!
This page was generated in 0.225 seconds.
