6 Pages <12345>»
An Appointment with ‘The Doctor’ - A Rossi Yamaha YZR-M1 Build Diary Options
#41 Posted : 28 October 2019 21:21:07
BigGrin So, have finally received Pack 9. Massive box for what could probably have fit in a jiffy bag, but hey, better safe than sorry Cool
In this pack, we get:
Stage 32) The oil pump, cover and coupling
Stage 33) The clutch bell and plates
Stage 34) Final clutch parts
Stage 35) Coolant hose, pipes and starter motor
#42 Posted : 28 October 2019 21:22:47
Stage 32.
Assembly of the oil pump and cover, and attaching the coupling to the engine block. The two halves of the oil pump are pressed together and attached to the block. The coupling mounts onto the block with the slots provided.
#43 Posted : 28 October 2019 21:24:32
Stage 33
The clutch bell and plates come together:
The clutch plates sit onto the spline in the clutch bell by aligning the notches.
#44 Posted : 28 October 2019 21:25:49
Stage 34
Assembly of the final clutch parts:
The box sits in the recess on the block, aligning the two pins. The tube is then attached from the pin on the block to the front pin on the box.
The final parts that make up the clutch is then attached, and sits in the engine block with the two locating pins.
#45 Posted : 28 October 2019 21:32:28
Stage 35
Fitting the coolant hose, pipe and starter motor:
The coolant pipe is inserted into the slots on the cylinder head cover, with the hose pushed onto the end of it. Once the starter motor is assembled, it is attached to the engine using the two pins near the clutch assembly.
This completes stage 9
#46 Posted : 28 October 2019 22:10:15
alemo
#47 Posted : 29 October 2019 11:17:01
Coming along nicely and a good way to do the build diary.
Alec
Adapt, improvise, overcome.
#48 Posted : 29 October 2019 19:31:55
BigGrin Thanks for looking in guys, much appreciated ThumpUp
#49 Posted : 30 October 2019 09:15:19
Looks great Gray, beautiful work.....Cool Cool
#50 Posted : 30 October 2019 17:09:58
Thanks Alan, appreciated ThumpUp
#51 Posted : 30 October 2019 19:45:09
Just catching up on your build. Certainly coming together very nicely, great work.Cool
#52 Posted : 01 November 2019 16:14:38
Just caught up with this Gray. Looking very nice. You're doing a cracking job!Love
#53 Posted : 12 November 2019 14:26:27
BigGrin Mark, Phil, thanks for looking in and your comments. Always welcome ThumpUp
#54 Posted : 12 November 2019 14:28:20
I must have missed your last update.
It's looking fantastic. Keep it coming.
Roy.
#55 Posted : 24 February 2020 21:32:12
Thanks for looking in, Roy ThumpUp
Well, I’ve had a right mare with Stage 38! I managed to split one of the plastic pipes, and could I get one anywhere?
In the end I had to resort to asking c/s if they could send me replacements. Thankfully, they did!
I know they get a bad press sometimes, but I’d just like to say a huge thank you to those guys BigGrin ThumpUp
Next stages to follow.....
#56 Posted : 03 March 2020 19:55:23
Pack 10
In this pack, we see construction of the manifolds and throttle bodies, intake ducts, hoses, gaskets and rear shock absorber.
Stage 36
The Manifolds and Throttle bodies.
The manifolds and throttle bodies are assembled by just push-fitting the parts together. These are then attached into the holes in the engine block, making sure the holes are outermost. The throttle return rod now fits to the throttle bodies, with the two pins fitting into the fore-mentioned outer holes.
This completes stage 36
#57 Posted : 03 March 2020 20:07:28
Stage 37
The Intake ducts.
The two support rods are attached to the two side covers, noting the orientation. Fit the two intake ducts to the side covers.
Retrieving the airbox from Stage 22, the ducts sit inside onto the four posts. The airbox cover then sits on top, and are locked together with the hooks over the pins.
This completes stage 37
#58 Posted : 03 March 2020 20:24:23
Stage 38
Hoses and Gaskets.
This was my nemesis stage Crying . The two thicker tubes are fitted to the 'A' and 'B' couplings. That part went ok. However, when trying to fit the hoses to their mounting points on the engine, one of the pipes split. I had tried widening the pipe with a tooth pick, finally resorting to putting it in hot water hoping to expand the pipe. No joy, it split while fitting! Because they have to be cut to a precise 45mm, cutting it and starting again meant the pipe was now too short. I tried various modelling supplies stores, but no joy. In the end i just rang Customer services, and bless'em they sent me one out a couple of weeks later Love .
So, the larger pipes were installed in place, but i had another issue when fitting the two smaller pipes. The two couplings would not mount into the respective holes on the engine block. I resorted to increasing the size of the holes and securing in place with a spot of superglue RollEyes.
At least the two gaskets fitted easily enough BigGrin
This completes stage 38
#59 Posted : 03 March 2020 20:31:25
Another great update.
It looks like a really detailed kit. Keep it coming.BigGrin
#60 Posted : 03 March 2020 20:33:35
Stage 39.
The Rear shock Absorber.
The shock absorber body is fitted into the spring. The rod is inserted down through the spring so that the 'window' aligns with the screw holes. Insert a screw into the shock absorber body to secure the shaft, but still allows the spring to compress.
Mount the shock absorber assembly to the engine and secure with the screw provided, again allowing for movement.
This completes stage 39 and Pack 10
6 Pages <12345>»
This page was generated in 0.298 seconds.
