spity360 Options
spity360
#1 Posted : 17 August 2011 20:52:56
Hi all
Frustration has set in....all day trying to get the Wales right
is there a formula a measurement to get the middle wale in the right
place tried the pic in the issue 42 tried matching it with other builds
in their photos to no avail if anybody can help please do
PaulCrying Crying Crying
cal
#2 Posted : 18 August 2011 19:42:45
hi spity all i did was put them on as per the book & then ajust them till they look right, having probs with the lower one now tho
#3 Posted : 18 August 2011 19:46:12
hi spity,if you click on my build,the link is beside my mug, icon thingy those pics should help.
jonny7england
#4 Posted : 18 August 2011 20:24:42
I had problems with my wales, and understanding that everybody's builds were different, I followed the mag, and also looking at other builds and adjusted my wales to as close to the plans in the mag...mine are a few millimetres out here and there, but as close as damn it...hope this helps...
BigGrin
alantait
#5 Posted : 18 August 2011 20:30:57
Hi Spity, i followed the magazine and also took a good look at the more experienced builders photos such as karl and son of bulwark. if you use a decent glue it will allow you to adjust to your own satisfaction by looking along the length of the build then a single pin to allow more movement
current builds
Mr.Quist
#6 Posted : 18 August 2011 21:42:40
Hi Spity,
I also tried to follow the mag, even though the image is not very precise for this.To keep the distance between the whales I used a piece of scrap wood
It was't easy to maintain the "swing" but I think it is okay.
Hope this helps. Check for images of this stage in my german build diary here and here.
Will put them in my diary here in this forum later.
Cheers, Timm
My build diary here
HMS Victory
Atholm
#7 Posted : 19 August 2011 09:16:07
Hi Spity360
I had the same problem. The instructions are not very clear. After reading them a number of times looking at Tomick official build and other build diaries I used the following points as the top of the center wale.
Bow end is clear from the instructions,the top of middle wale is level with bottom of slot in bow section.
The stern end I used the center point of the lower window aperture of the gallery as the top of the center wale
The other reference point I used was the bottom of the entrance port were the top of the center wale is just below the entrance port.
Then create a sweeping curve between these points.
I has installed the top 3 planks of the lower wale 12mm away (using a pair of compass to mark the 12mm space) from the bottom of the center wale and they seem to be as in the position at the stern as per the instructions.
Hope this helps.
Happy building
Athol
