how do i go about replacing faulty engine LEDs? Options
x_dfo
#1 Posted : 18 October 2019 21:56:23
Rank: Advanced Member
I recall seeing some posts about this but I can't seem to search the forums so I'm reaching out to see if anyone knew if deagostini was replacing these for free or am I stuck buying a 3rd party strip? both of mine have dim and failed bulbs.
Also are they supposed to flicker?
Cheers,
Charlie Dude
#2 Posted : 18 October 2019 22:24:53
Rank: Amateur Level 1
Call their customer support number and they'll send you replacements. That's what I did for my R2D2. Bad thing is, they come from the UK and it takes 10 days. I'm on day 7, so we'll see what happens?
#3 Posted : 18 October 2019 22:28:01
Not sure what stage of the build you are at, but if you are testing them out and using the battery pack, you may want to check the batteries as they will effect the working of the lights if low on charge.
x_dfo
#4 Posted : 18 October 2019 22:38:13
As far as I know, these batteries are straight from the pack, so they should be fresh.
This page was generated in 0.261 seconds.
