 Shells painted and fitted into the racks with the etch straps [ 6 saved for the turret racks]. You can also now see why I did not remove the ejector pin marks as I knew the shells/cases would hide them. The upper deck was masked off then glued to the lower hull ready for undercoat and paint. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Highly detailed as usual from you Andy, looking fab..... Regards Alan
 Thanks for looking in and your comments Alan Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Shells look great Andy. Mark Regards Markwarren (Mark) Admin
 Thanks for looking in Mark and your comments, The undercoat has been added pics to follow Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 The hull and turret were first undercoated in MIG one shot black primer and when dry MIG olive drab base was sprayed on the parts. Started to prep the workable tracks. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Andy, making excellent progress..... Regards Alan
Very nice work Andy.  Just been ready the latest Mig weathering mag, How to paint IDF Tanks. https://www.migjimenez.com/en/th...ering-guide-english.htmlGet mine through subscription on my IPad to read, much cheaper that way. Mark Regards Markwarren (Mark) Admin
 Hi Mark thanks for looking in and your comments, Im looking to buy that set sometime soon and there great mags Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Tracks were undercoated then painted steel for the pins/horns and rubber black for the pads. The track set works by glueing an upper and lower pad together with the pins captured by the pads then the horns are added. I tried the finished track on the Achilles to see how they look and there much better than I thought [ just need to add 3 more pads to complete the track ], they take time to assemble but the results speak for them selves. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
All those track links, its almost as bad as painting decorations.....  .. Looking good Andy.... Regards Alan
Those tracks look great, time consuming, but worth all the effort. Great work Andy. Mark Regards Markwarren (Mark) Admin
Hi looking good Andy,tracks same build up as my Meng Abrams time consuming but well worth it ,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
lovely build so far Andy  the extra`s are really worth it  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Thanks for looking in and your comments both Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Tracks are done, the spare pads and teeth in the picture are to join each track when fitted on the tank. Bronco are quite generous with there sprues as I have one complete set of each left although the carpet monster did not get to feast on any parts this time round. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
You've done really well to avoid feeding the carpet monster, no doubt it will get fed at some stage.....  .. Nicely done Andy... Regards Alan
 Decals added front and rear, tools made painted and fitted, 50 cal assembled/painted, exhaust made up crusted up/painted and the recovery hawser made up painted and fitted. Started to apply the winter wash camo, im using Precision Ice and Snow winter camo paint for this. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
