 Rank: Pro  Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
Thanks guys, for looking in and your kind comments. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 10 - Stage 105 In this stage I built the Upper galleries on both sides and also fitted the stern panels of all three galleries. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 10 - Stage 106 In this stage the stern gallery balconies are assembled. I painted the sides of the hull behind the balcony walls at this stage to make it easier. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Joined: 25/01/2019 Posts: 48 Points: 177 Location: Texas, USA
Mark, where is you find Part D on stage 105 step E? It is not on the laser cut fret provided. Yours is looking great! Thanks John 73 de John W1XQ (ham radio operator) Amateur Radio Lighthouse Society Operator aboard Museum Ship USS Stewart and USS Cavalla
Current attempt: Soleil Royal Prior Builds: Nantucket Lightship, South Goodwin Light vessel, Natchez Packet Paddlewheeler, Souhern Belle Paddlewheel Towboat
Senior moment, I found them. John 73 de John W1XQ (ham radio operator) Amateur Radio Lighthouse Society Operator aboard Museum Ship USS Stewart and USS Cavalla
w1xq wrote:Mark, where is you find Part D on stage 105 step E? It is not on the laser cut fret provided.
Thanks John Hey John, Part D that you are looking for was included on the fret received with stage 100. I've attached a screen shot of the fret for you. If you threw it out by mistake, customer service will replace it for you. Just call them and request they ship you a spare stage 100. They do not charge for this service. Are you posting a build diary? Would like to see your progress Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
w1xq wrote:Senior moment, I found them.
John LMAO  so then disregard my last post. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Thanks Mark. No, no build diary as I gave up on how to post pics. 73 de John W1XQ (ham radio operator) Amateur Radio Lighthouse Society Operator aboard Museum Ship USS Stewart and USS Cavalla
Pack 10 - Stage 107 In this stage I finished build of the stern gallery balconies. The center plates on the rear balcony walls were fitted then all surfaces were sanded smooth. All joints and gaps were filled with putty and sanded down. A clear matte sealer was applied to all the raw wood and allowed to dry Then stern galleries and balconies were painted with French Blue (Vallerjo). the sides of the hull from just below the top row of gun ports up to the gunwales was also painted French Blue. That's all for this stage. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 10 - Stage 108 this stage is quick and simple. The bell and bell arch was built and fitted to the aft edge of the forecastle deck. I drilled holes along the deck edge fot the hand rail. I'm waiting for more 10mm columns from customer service and will finish the hand rail later. 2 2-step ladders were fitted going to each side of the forecastle deck. Moving on, Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Looking good Mark, coming along very nicely indeed.... Regards Alan
Coming on very nicely Mark. Mark Regards Markwarren (Mark) Admin
Pack 10 - Stage 109 In stage 109 I fitted the last of the 3x3mm posts to the port and starboard sides of the forecastle deck. This is also the stage where the gun ports are suppose to be painted. I chose to complete this step BEFORE the final hull planking was applied. I painted and fitted the 16 round gun ports to the upper decks. This completes the stage. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 10 - Stage 110 I started this stage by building and painting 20 more gun port doors. 2 windows were fitted to the upper ports on the bow bulkhead. The stern gallery balcony window columns were glued into positions shown. Then the edges of the transom were built up with 2x5mm wood strips. The strips were painted French blue. The larger columns were then fitted to those strips. This completes stage 110. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Looking good, nicely done..... Regards Alan
Pack 10 - Stage 111 Drilled the holes in the center of dummy gun ports and fitted port frames to the upper row of ports. The Windows were installed on the middle and lower stern gallery balconies. The mizzenmast chainwales were fabricated and fitted to the outside of the bulwarks. Stage complete Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 10 - Stage 112 The square window was fitted on the hull just below the mizzen chainwale. The panes of the windows, including the balcony windows, were painted to match the other windows. The 3 mast collars were fitted around the mast holes in the decks. The forward chainwales were assembled and fitted along the forecastle bulwarks. Next I started fitting the decorations to the ship. The stage is complete. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
She's really coming together now Mark, looking great..... Regards Alan
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Thats a very nice looking ship you have there , love the combination of the blue and gold Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
