 Rank: Pro   Groups: Registered, Official Builds Joined: 10/02/2012 Posts: 475 Points: 1,237
Hi All, I thought I'd share my most recent completion. It is a Model Factory Hiro 1/12 Ferrari 156 "Sharknose" This was about a year in the making, but wasn't worked on regularly. (Those of you who have built a MFH kit will understand...) The kit is primarily white metal, with pressure cast resin for the body, lots of PE, and rubber. experten attached the following image(s): Tired, Old, and Cranky!
Excellent work, and great finish. This one is on my list. Mark Regards Markwarren (Mark) Admin
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,192 Points: 15,725 Location: ipswich
That is a brilliant build. One to be proud of. I'll have to give these MFH kits a look.
Roy.
Its a stunner Mark. MFH kits are incredible. They are difficult to build and it takes a huge amount if skill to make them look as good as Mark did. They often have hundreds of parts and almost every detail of the original car is represented.They do need extensive test fitting to make sure everything lines up and they are as much an engineering project as a kit build.The instructions are pretty good but you often need to do quite a bit of research to get everything right.
There was a post on the MFH FB group about how some people think that modelers building MFH kits are somehow cheating because they have so much detail. I think the opposite is true.There is a ton of detail so you dont need to scratchbuild the extra parts, but getting everything to fit is very challenging.
Very impressive build you've done there Mark, she looks simply amazing.....  .. Well done and thanks for sharing.... Regards Alan
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Fantastic looking model ,looks so real Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Fantastic job done with this Sharknose kit. These MFH kits are time consuming but very rewarding.Excellent stuff. Malc.
 Rank: Pro    Groups: Registered, Moderator Joined: 20/01/2013 Posts: 161 Points: 455 Location: Celle, Germany
Wow đ fantastic đđź Der gesamte Baubericht und alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung. © Levelord
@work: X-Wing,Dodge Charger, MIG-29
Completed: McLaren MP4-23, Hummer H1, RedBull RB7, Easy Rider Bike, Jaguar E-Type, Porsche 911, Ferrari F2004, AMG DTM Mercedes, Ford Mustang, R2-D2, C57, Modellbahn,Rossi Bike,VW Käfer 1303,VW T1 Samba Bus
Thanks, guys! If youâre on the fence about a MFH kit, just bite the bullet, and do it! You truly wonât regret it! Next up, the Lotus 49! Tired, Old, and Cranky!
experten wrote:Thanks, guys!
Next up, the Lotus 49! Hi Experten. Will that be the Lotus 49B 1/12 just released by MFH or the earlier 49? Both look like great kits to build. ( very envious ) Malc
RM1 wrote:experten wrote:Thanks, guys!
Next up, the Lotus 49! Hi Experten. Will that be the Lotus 49B 1/12 just released by MFH or the earlier 49? Both look like great kits to build. ( very envious ) Malc Itâs going to be the Jim Clark 49 from the â67 British Gran Prix. Iâve got two versions of the 49B on order, the A and C. Tired, Old, and Cranky!
experten wrote:RM1 wrote:experten wrote:Thanks, guys!
Next up, the Lotus 49! Hi Experten. Will that be the Lotus 49B 1/12 just released by MFH or the earlier 49? Both look like great kits to build. ( very envious ) Malc Itâs going to be the Jim Clark 49 from the â67 British Gran Prix. Iâve got two versions of the 49B on order, the A and C. Jim Clark '67 GP sounds brilliant. Can't wait to see it progress. And you've got two of the 49B's ontheir way. Wow. Malc.
