issue 68 arm seal Options
ronald305
#1 Posted : 03 September 2019 01:51:30
hello there
I have a question how come the arm seal does not require screws to keep it in place from falling out like mine does or do they get fasten later in the construction thank you
Ronald
admin
#2 Posted : 03 September 2019 05:26:44
The “arm seal?” Do you mean the twist-lock shoulder mount cap?
It gets tighter when body panels go on.
ronald305
#3 Posted : 03 September 2019 14:41:35
no the silver arm seal in issue 68 it just says snap in to place but it doesn't stay in place
Ronald
#4 Posted : 03 September 2019 15:58:33
The silver arm plate will hold itself in place when you come to attach the arm assemble to the body.
ronald305
#5 Posted : 03 September 2019 16:35:37
ok thanks Mark
Ronald
R2D2Nut
#6 Posted : 04 September 2019 14:50:41
In some cases, the part snaps in and stays, but in most cases, it slips out. I'm not saying to do this, but I added 2 drops of CA just to tack it in.
Fred
ronald305
#7 Posted : 04 September 2019 14:58:53
ok thanks Fred
sounds like a good idea because mine keeps popping out
Ronald
R2D2Nut
#8 Posted : 04 September 2019 23:00:57
Just don't completely glue it. Just a dab to hold it.
ronald305 wrote:
ok thanks Fred
Ronald
tschwand
#9 Posted : 08 September 2019 14:47:51
I assume you mean the half round pieces that attach to the body at the shoulder. If so, a drop or two of superglue will hold for now, but when assembled, the legs will prevent those pieces from going anywhere.
This page was generated in 0.097 seconds.
