The 1/1 kit I've been building today Options
kpnuts
#1 Posted : 26 August 2019 20:03:12
Hi all had the family over yesterday (to help with this) decided it was way too hot so I've been trying it on my own.
https://i.ibb.co/QMZk16H/IMG-20190826-19493.jpg
We will be adding power at some point, still got the glazing to do and adding the trim but quite pleased so far.
It will help supplement my modeling area for the messy stuff.
#2 Posted : 26 August 2019 20:27:30
BigGrin Nice project ,if your using it as a new man cave for modeling I would recommend you insulate the walls and add an inner layer of wall. This will benefit you all year round and be very useful for keeping a constant temperature if your going to be painting in there too.
Also consider adding double glazing, power and heating for the winter months.Cool
kpnuts
#3 Posted : 26 August 2019 21:19:15
I was thinking of adding plaster board walls and insulation not sure it's well enough built to worry about double glazing.
#4 Posted : 26 August 2019 21:59:27
that look like a ton of fun Ken .Although with your history of modifying your models I am surprised you havent added a turret or clock tower to the shedLaugh
kpnuts
#5 Posted : 27 August 2019 06:44:46
BigGrin BigGrin BigGrin
#6 Posted : 27 August 2019 10:14:18
A thought Ken...
Did you wood-treat the outside of the panels up against the fence?
Factory shed treatment is notoriously naff and you don't want the bottoms of your panels starting to go soggy after a few years.
Also, I wouldn't use plasterboard in a shed. It will absorb moisture from the air and start to swell at the edges.
A cheap carpet on the floor makes a big difference to keeping it warmer too.
Have fun.
Roy.
kpnuts
#7 Posted : 27 August 2019 21:19:13
Thanks for the info Roy.
This page was generated in 0.106 seconds.
