12 Pages «<678910>»
Soliel Royal by Mark Options
mwstratton
#141 Posted : 16 August 2019 01:24:40
Looking good, lovely work....Cool Cool
Thanks Alan.
Under the Bench:
mwstratton
#142 Posted : 16 August 2019 01:28:27
Pack 9 - Stage 94
Started out by repeating the previous stage on the starboard side.
Next I shaped and smoothed out the round gun ports and made a recess on the rail for another round port 35mm forward of the first one. Finished the stage by test fitting the round ports.
This was repeated on the other side of the ship.
mwstratton attached the following image(s):
Under the Bench:
mwstratton
#143 Posted : 16 August 2019 04:00:52
Pack 9 - stage 95
This stage is more work on the rails and round gun ports.
Under the Bench:
#144 Posted : 16 August 2019 07:59:29
Very nice work Mark, looking great.Love
#145 Posted : 16 August 2019 08:11:41
That is coming aling very nicely and is really taking on some great detail now.
Hope it continues well
#146 Posted : 16 August 2019 19:09:43
This is turning out to be a very nice build indeed, very well done Mark....Drool Drool
mwstratton
#147 Posted : 17 August 2019 06:56:58
Pack 9 - Stage 96
Continuing the rails aft to the complete the side rails of the quarter deck. Next the the hand rail along the edge of the quarter deck was fitted. 2 two rung ladders were placed leading to the quarter deck.
Under the Bench:
mwstratton
#148 Posted : 17 August 2019 08:40:59
Pack 9 - Stage 97
This was a short and simple stage. The dolphins were fitted to the bow along the top of the beak and the bottom of the prow. 2x4mm molding was glued from the dolphins to the stern 10mm apart and 10mm from the bottom of the gun ports.
Under the Bench:
#149 Posted : 18 August 2019 09:22:46
Taking shape very nicely Mark.Love
mwstratton
#150 Posted : 18 August 2019 10:34:36
Pack 9 - Stage 98
I've fitted the lower gallery deck to the stern of the ship. The gallery deck supports were added. Next the gallery side panels were glued in place. Finally, the gaps between the gallery sides and the sides of the hull at the stern were filled with 2x5mm planks.
Under the Bench:
mwstratton
#151 Posted : 18 August 2019 21:53:02
Pack 9 - Stage 99
The side rails are completed all the way to the transom. along with the hand rail between decks. Next, the stern gallery decks are fitted and the sides of the lower gallery is added.
The hull is given a final sand and any flaws are fixed. 3 coats of acrylic satin clear coat is applied.
Thanks for following
Under the Bench:
mwstratton
#152 Posted : 21 August 2019 01:37:51
Pack 9 - Stage 100
In this short stage, the knees were assembled and fitted to the transom. 2 doors were installed on the bow bulkhead.
Moving on
Under the Bench:
mwstratton
#153 Posted : 21 August 2019 02:26:22
Pack 9 - Stage 101
I started out by painting the brass windows and then installing them on the poop deck and quarter deck bulkheads.
A pin rail was fitted aft of the main mast hole. One of the large rails was placed forward of the hole.
2 lockers were fabricated and installed on the quarterdeck.
A 5 rung ladder was fitted leading to the poop deck. 2 ladders were installed leading to the quarter deck.
That's all folks.
Under the Bench:
mwstratton
#154 Posted : 21 August 2019 02:32:40
Pack 9 - Stage 102
I painted the back side of the transom. The windows for the stern galleries were painted, built and installed.
I installed the heads on the bow deck.
Under the Bench:
#155 Posted : 21 August 2019 07:33:45
This is taking shape at a pace.
It looks really nice.
Hope it continues well for you.
mwstratton
#156 Posted : 21 August 2019 09:56:23
Pack 10 - Stage 103
The rail columns were fitted across the forward forecastle rail. I then prepared the forecastle side gunwales to receive the hand rails.
I was unable to finish this stage because for some reason, I came up 20 columns and 2 hand rail fittings short. Hopefully customer service can get me some replacements soon.
With the exception of the missing parts, this stage and pack is completed.
Under the Bench:
mwstratton
#157 Posted : 18 September 2019 22:20:23
Pack 10 - Stage 104
The handrails around the forecastle deck were completed.
The Rails on the forward edge of the Poopdeck was also fitted.
Simple stage and is now complete.
Under the Bench:
#158 Posted : 19 September 2019 06:52:00
Excellent build! Loving it!
#159 Posted : 19 September 2019 07:14:32
You are doing a great job Mark, looking excellent.Love
#160 Posted : 19 September 2019 08:43:35
You're making excellent progress Mark, she's certainly has the makings of turning out to be a stunning build..... Very well done....Drool Drool
12 Pages «<678910>»
This page was generated in 0.794 seconds.
