Hi
I was hoping someone can help. I've mucked up on my front suspension (rounded the screws) and need to find replacement screws. Its issue 10-11 i think. What size screws are they and where can i get them from? I've seen tips for using lubricant when screwing them in so i'm gonna try that.
Thanks
fixed - my screw driver was slightly too big. at least from now on it will be better!
 Rank: Pro  Groups: Registered
Joined: 27/05/2011 Posts: 256 Points: 774 Location: barrow in furness
I had the same prolem! There is a spare screw with each "set" of screws we get. Mine was down to a broken screwdriver! If at first you don't succeed........skydiving is not for you!
Joined: 05/04/2011 Posts: 266 Points: 784 Location: Essexshire
Go buy a set of these on ebay 120686481203. 6 fantastic screwdrivers and worth every penny. Not worth buying one at a time
 Rank: Beginner Level 3  Groups: Registered
this is the problem I'm having, but I have the Wera PH 00 driver, di I need the set of 6? It would make sense if this was the problem as the suspension screws (only) just don't seem the right fit to my Wera screwdriver?
