Mark's Custom 67 Shelby Mustang Options
mwstratton
#1 Posted : 13 August 2019 06:37:29
Thanks to DeAgostini's Summer sale here in the States, I have just purchased the 12 month Shelby subscription.
I've decided that this will be a complete custom build, complete with a Candy paint job.Drool I won't be posting stage by stage build, but will detail all the custom work.
Hope you all enjoy this diary.Blink
Mark.
Under the Bench:
#2 Posted : 13 August 2019 06:49:41
Sounds a good build Mark looking forward to seeing your build diary.
Trev.
#3 Posted : 13 August 2019 08:10:55
Hi Mark, looking forward to seeing what you do with this one.Love
mwstratton
#4 Posted : 13 August 2019 10:33:54
So Here we go.
I've painted the trim and valve stem of the front wheels, the steering knuckles, and brake rotors. Using 220 grit sand paper, I scuffed the brake rotors in a circular fashion to mimic rotor wear. The road surfaces of the tires were also scuffed to show wear and tear.
I will be posting a complete paint list next and will keep it updated as I move through the build.
I'm so excited to get this started. This will be my first custom build in about 40 years as I've just started back modeling this January.ThumpUp
mwstratton attached the following image(s):
Under the Bench:
mwstratton
#5 Posted : 13 August 2019 14:21:23
Custom 1967 Ford Shelby GT 500
Paint list
Updated 15 August, 2019
Vallerjo Nato Black (71.251) - Wheel Trim, Valve stems
Model Masters Flat Gull Gray - Wheel weights
Vallerjo Red (71.003) - Disc Brake Calipers
Vallerjo Black (71.057) - Steering knuckles, Rocker Arm Covers, Air Cleaner Cover, Vacuum Bodies
Vallerjo Aged White (71.132) - Air Filter
Vallerjo Gold (71.066) - Carburetors
Vallerjo Blue (71.004) - Oil Filler Cap
Under the Bench:
#6 Posted : 13 August 2019 15:02:53
Looking forward to seeing what you do with this beastie.
It's a great, fun kit with lots of scope for upgrades - particularly in the engine bay.
Roy.
mwstratton
#7 Posted : 14 August 2019 05:06:54
So today I finished the front wheel assemblies. I painted the carburetors and tops of the rocker arm covers and air cleaner. Also painted the air cleaner element. I used some black sandpaper to simulate the valve cover gaskets. Once assembled I lightly weathered the entire upper end of the engine to look like it has been used.
Wrapped these sub-assemblies in bubble wrap and stored away for later.
Under the Bench:
