Looks great.You dont need a 3d printer with your scratchbuilding skills make!! I was talking with a friend the other day about the worst kits we have ever built and he was talking about the airfix car kits and how bad they were.He sent me a pic of a car kit that he stabbed with a knife because he got so frustrated with it I am sure you will coax a stunner out of this kit like you did with the podracer. Carl
Superb skills being shown once again Mark, coming along beautifully..... Regards Alan
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,867 Points: 20,918 Location: Northamptonshire, England
Many thank Carl and Alan for your comments. Carl, not quite got to that stage yet. Mark Regards Markwarren (Mark) Admin
 All looking good and nice work from you Mark . Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Many thanks for your comments Andy Mark Regards Markwarren (Mark) Admin
Abslout top work on rack. Very impressive clean and perfect scratch! Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
A little more done to the car. I have mixed up a base coat for the main body colour and sprayed painted it and left to dry for a for a few days. Once the gloss varnish has been applied then the blue will look deeper and darker, I think the colour should be about right when finished. I did varnish the inside of the engine compartment, just a quick spray as it is never as shiner inside as the main body anyway. I then painted the underside of the car, painted the framework black and painted the gearbox silver. I then set to on the engine fixing it in place and adding some more detail to the engine compartment. I added the detail to the bonnet with the silver and red triumph badge and lettering. I glued the inner body parts together along with the engine block. As you can see, I had to use plenty of clamps as the body was slightly warped and they were needed to straighten it out. Told you it was a bad kit. Once all fixed and glued, I added some extra cables and bottles to the engine compartment. The last couple of pictures are the main body fitted on as a test fit, work needed there. The final picture shows some material I have to make the convertible roof, once I’ve made the frame, which is pretty much the same colour as the original car. The roof however will be in the down position. Next, I will be painting the dashboard which has already has the base white coat and allowed to dry before painting the wood effect using water colour pencils and translucent paints. Thanks for looking, more soon Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Looking really good there Mark, love the body colour you've chosen....  .. Very well done.... Regards Alan
Many thanks Alan. Mark Regards Markwarren (Mark) Admin
 Coming together nicely and nice blue. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Many thanks for your comments Andy. This time I have painted the dashboard. The one that was in the car was quite a light wood with yellow undertones. I first primed and painted the part white. I then used water colour pencils, yellow, light brown, and a red brown. Using plenty of water, get the colour and effect you are happy with and allow to dry for a day. The next step was to spray a thinned down Tamiya clear yellow, again allow to dry before spraying Tamiya clear orange. Again, allow these to dry. I then spayed gloss varnish over the whole piece and applied the decals I got from slot cars. Once these were dry, it had a good coating of gloss varnish again. I then painted the edging and ventilation vents black, and some of the knobs chrome. The pictures don’t really do it any justice as it doesn’t show the high gloss of the wooden part very well. the very last picture show how small this was, a very good magnifying glass was used in this exercise. More soon. Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
A little more done this evening. I have placed the chrome strips on the side of the car using some silver tape, thinly cut and carefully placed. The last picture is with the bonnet attached. The chrome badge is blued out as you can see, as I gave the bonnet another coat of blue paint, so this will have to be painted again. The next step is to place all the chrome fitting such as the handles and the lights before I give the body a high gloss coat. More soon. Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
 Rank: Pro Groups: Registered
Joined: 25/02/2017 Posts: 340 Points: 1,019 Location: surrey
Great work on the dashboard Mark. So small yet so much detail. A credit to your build. Andy.
The dashboard looks amazing and I love the body color.you have really transformed this crappy kit into something special
Many thanks Andy, Carl for your comments and looking in. Mark Regards Markwarren (Mark) Admin
Stunning work Mark, always great to see a true artist at work..... Regards Alan
 Looking good and nice work Mark, the walnut dash looks spot on. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,061 Points: 15,329 Location: ipswich
Just amazing what you have done with such a grotty old kit. Cant wait to see the end result.
Outstanding Mark  love the dash  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thank you guys for your comments.  For something that was going to be a quick build, it is taking longer than I thought. Mark Regards Markwarren (Mark) Admin
