Measure display case please Options
pbhawkin
#1 Posted : 07 February 2019 00:43:23
Rank: Beginner Level 3
Hi All,
Can someone please measure the display case (wooden base dimensions and 'glass' sides) that come with the subscription?
I am looking at making a custom one and am interested in what size the original case is.
I plan to have a mirrored base (so you can see under the car) and have the car mounted on two supports. As well as perhaps having the doors open too.
Peter
pbhawkin
#2 Posted : 08 August 2019 05:53:30
6 months later and I assume no one has the display case (judging by a couple of threads) or haven't got around to measuring it.
I am still interested in the dimensions and even a photo of it in the case to see how much room there is around the car (IE can it be displayed with the doors, bonnet and boot open?).
#3 Posted : 08 August 2019 08:59:21
Confused Don't know if this helps, as i didn't realise this came with a case as part of the subscription.
I was going to say that the display case on sale would fit (but not very attractive is it).
https://www.model-space....lay-case-modelcars.html
Car dimensions: Length: 590mm (23.2”) | Height: 170mm (6.7”) | Width: 230mm (9”)
Display Case dimensions: Length 634 mm, Height 220 mm, Depth/width 294 mm
Cheers Gray
This page was generated in 0.085 seconds.
