Stage 38 - The Curcuut Boards Options
Dave the tank
#1 Posted : 04 August 2019 15:33:11
Rank: Newbie
Hi all,
Having purchased the model in full the kit arrived in a very large box. All was well but I had two stage 38 and a note saying a replacement stage 38 was enclosed and to be used. However said note was not attached to either stage package nor was a reason given. Can anyone advise the reason for the replacement as both packages look the same to me. I will say that one of packages does not contain the warning children.
Look forward to hearing from someone.
Dave the tank.
#2 Posted : 04 August 2019 16:08:04
On the circuit boards is there a label or any printing on the board with a version or revision number?
If there is that might be a good starting point as to which needs using.
admin
#3 Posted : 04 August 2019 16:31:40
Hi,
Attached is a picture from a member of the German Forum support team, Levelord. It shows the old on the left, and the new on the right.
Dave the tank
#4 Posted : 04 August 2019 16:40:02
Rank: Newbie
On one of the circuit boards does contain additional printing although it doesn't make sense, to me at least, I will use these. Hopefully it will not blow itself up when I turn it on. Thanks for your help.
Dave.
Dave the tank
#5 Posted : 04 August 2019 16:42:00
Rank: Newbie
Thanks Mark thats the set I will use.
Dave
Levelord
#6 Posted : 04 August 2019 18:02:21
Groups: Registered, Moderator
Hello,
in the German forum we have the same problem. Modelspace already knows. Currently we are waiting for an information on how the subscribers get the new boards.
Lg Sascha
Der gesamte Baubericht und alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung. © Levelord
@work: X-Wing,Dodge Charger, MIG-29
Completed: McLaren MP4-23, Hummer H1, RedBull RB7, Easy Rider Bike, Jaguar E-Type, Porsche 911, Ferrari F2004, AMG DTM Mercedes, Ford Mustang, R2-D2, C57, Modellbahn,Rossi Bike,VW Käfer 1303,VW T1 Samba Bus
GilShapley
#7 Posted : 28 May 2020 15:59:10
I have also purchased the complete kit to give me something to do during lockdown.
Stage 38 is giving me some problems and I hope you may be able to clarify for me.
There are 3 circuit boards, two I have fitted Ok but the IR board is giving me a problem. Having been through the build instructions I cannot see where this board is to be fitted. What am I missing?
Any help you can give would be much appreciated
ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp
Current Build:-
#8 Posted : 28 May 2020 17:11:46
Hi Gil,BigGrin
Think what you are looking for is in issue 62 in the link below:
https://forum.model-spac...spx?g=posts&t=25864
This page was generated in 0.183 seconds.
