25 Pages «<56789>»
Gandale's Vasa Build Options
#121 Posted : 30 July 2019 23:33:27
Thanks everyone for looking in and your comments, appreciated.....Cool Cool Cool
#122 Posted : 31 July 2019 11:40:41
Stage 105 Contents: Stem, Stem Frames and Stem Decorations.
Retrieve decorations C144, C144a, C144b, C144c, C144d, C144e, C144f, C144g and C144h from stage 104. Remove any burrs or flash and apply a coat of metal primer, leave to dry. Follow the painting guide provided within the instructions to paint the decorations. When dry, carefully store the decorations in a bag labelled with this stage number.
Remove the two stem halves BS1, the decoration BSA from their frets and smooth all edges to remove any ash and burrs. Glue the decoration BSA between the two stem halves BS1 ensuring the upper edges of the three parts are all aligned. Now apply some wood putty along the edges of the stem to fill the joins between the pieces, keeping the notches clear. When dry, sand the edges smooth. Note: As I’m using wood stain, I chose to use dark coloured wood putty.
Separate the frames BS2-BS10 from the fret and sand all edges smooth. Tests fit and glue the frames BS2 into the first aft notch of the stem. The frame should be positioned at a right angle to the stem. Now test fit and glue the remaining frames to the notches in the stem, making sure each frame is at right angles to the stem.
Store any unused parts in a bag labelled with this stage number.
This stage is now complete.
#123 Posted : 01 August 2019 08:37:40
BigGrin All looking good and nice work AlanCool
#124 Posted : 02 August 2019 09:14:55
Nice work Alan, you must be able to do those decorations in your sleep.LOL
#125 Posted : 02 August 2019 14:27:12
BigGrin stem's taking shape Alan Love Great work as usual ThumpUp
#126 Posted : 02 August 2019 16:27:41
Thanks for looking in guys, appreciated....Cool Cool
#127 Posted : 02 August 2019 17:00:31
BigGrin Very nicely done Alan Cool
Martyn
#128 Posted : 02 August 2019 17:09:30
Very neat work Alan.
I like how they have used that brass etch detail rather than trying to produce it as a wood section.
#129 Posted : 03 August 2019 17:15:43
Wow great workDrool Drool Alan looks superbBigGrin regards PhilCool
#130 Posted : 03 August 2019 22:49:38
Martyn, Tony & Phil, thanks guys for looking in and your kind comments, always appreciated....Cool Cool
@Tony, the way the stem decorations are build up is very clever as you will see over the next couple of build stages.... The brass etch plate you see is just the base onto which the painted parts are attached... I'm quite impressed with it over all....Cool Cool
#131 Posted : 04 August 2019 15:20:36
Hi Alan looking great ,keep up the good work,cheers mick,BigGrin
#132 Posted : 04 August 2019 16:05:56
Look forward to seeing that. It does look a very well thought out and detailed kit.
#133 Posted : 05 August 2019 18:13:59
Clean and tidy Alan
Trev
#134 Posted : 05 August 2019 22:16:11
Thanks Trev, appreciated....Cool Cool
#135 Posted : 05 August 2019 22:16:46
Stage 106 Contents: Stem Platform, Rails, Side Walls and Gallery Parts.
Remove any burrs or flash from the gallery parts received with this stage and apply a coat of metal primer. Follow the painting guide provided within the instructions to paint the decorations. When dry, carefully store the decorations in a bag labelled with this stage number.
Retrieve the stem decorations supplied with stage 105. Remove parts BSB, BSC, BSD, BSE, BSF and BSG from the fret and apply a coat of metal primer. Once again, follow the painting guide provided within the instructions to paint these decorations.
Remove parts BS11, BS12, BS13, BS14 and BS15 from the fret then smooth the edges. Glue the two rails BS12 together, making sure the edges are aligned. Then dry sand the edges of the combined pieces. Now drill four 1mm holes along the centre of the rail, the holes should be 6mm apart. Now glue the two rails BS13 together, aligning the edges. Sand smooth then drill three 1mm holes, 5mm apart (not 6mm as stated in the instructions). Glue the assembled parts BS12 and BS13 onto the tops of the stem frames BS6 and BS8.
Paint or stain the stem with the same colour as that used for the hull. Now paint the bow platform dark brown, RAL8022.
#136 Posted : 05 August 2019 22:36:25
BigGrin All looking good and nice work AlanDrool Drool Cool
#137 Posted : 06 August 2019 11:49:14
Wow this is looking great!
#138 Posted : 06 August 2019 15:52:58
Very neat painting on the detail parts Alan.This will be a stunner once finished.
#139 Posted : 06 August 2019 22:23:01
Thanks guys for looking in and the positive comments, greatly appreciated as always....Cool Cool
#140 Posted : 07 August 2019 09:57:38
Very nice work as usual Alan.
25 Pages «<56789>»
This page was generated in 0.264 seconds.
