80 Pages «<5354555657>»
#1081 Posted : 25 July 2019 22:01:56
A bit more work completed this week, but not loads as my flat is cooking!LOL
I started by drilling into the base of the lower deck gun to accept a 1.6mm brass dowel.
#1082 Posted : 25 July 2019 22:03:18
I then drilled the corresponding, locating hole into the lower deck.
#1083 Posted : 25 July 2019 22:05:29
I then began planking the lower deck in mahogany as per the original with 2.0mm wide x 0.5mm thick strips. I used 0.5mm plastic spacers to give me the correct gap. 0.5mm in 1/48 scale is roughly equivalent to 1 inch in real life.
#1084 Posted : 25 July 2019 22:07:45
I then ran out of mahogany strip!Blushing Blink. I have ordered more from Cornwall Model Boats, but in the meantime I started to cut away some of the planking to accommodate the rearmost water-tight ammunition container. A little more tidying up to do on this, but it's nearly there.
#1085 Posted : 25 July 2019 22:08:31
The water-tight ammunition container being tested for fit.
#1086 Posted : 25 July 2019 22:09:42
Well that concludes the update for this week.
Thanks for looking in, have a great weekend and happy modelling!Cool BigGrin
#1087 Posted : 25 July 2019 22:36:37
Really coming together now Phil, great work as usual.Love Drool Drool
#1088 Posted : 26 July 2019 07:08:40
Phil
Very nice.
Wood deck section looks very good.
#1089 Posted : 26 July 2019 13:42:10
Thank you Mark! Slowly but surely!BigGrin
#1090 Posted : 26 July 2019 13:42:49
birdaj2 wrote:
Phil
Very nice.
Thank you Tony. The mahogany really brings it to life!BigGrin
#1091 Posted : 27 July 2019 01:30:38
BigGrin Hi Phil all looking good and nice work. One question would the deck planking your just adding have cross members below them to aid drainage or was it just a front to rear drainage design.Cool
#1092 Posted : 30 July 2019 07:44:41
Hi Andy, good question. I imagine there would be cross members. Most of the photos I've seen don't show this detail, so open to artistic license. I've attached a photo of U995's deck so you can see the deckng, however, you can just make out what might be cross members. From a model making perspective, adding cross members would be detrimental to the strength, as the veneer i'm using for the planking is only 0.5mm thick, making it very fragile. Weight applied to any part not supported by cross members would easily break.
Phil.
#1093 Posted : 30 July 2019 14:48:59
Hi Phil,
Another amazing update. Your skills are astounding!!!
#1094 Posted : 30 July 2019 23:40:15
Love everything about this build, true work of art....Love Love Love
#1095 Posted : 31 July 2019 07:36:06
Your attention to detail is amazing! Great update!
#1096 Posted : 08 August 2019 22:51:11
Garth wrote:
Hi Phil,
Thank you very much Garth!Blushing BigGrin
#1097 Posted : 08 August 2019 22:52:46
Thank you Alan! Very much appreciated!Blushing BigGrin
#1098 Posted : 08 August 2019 22:53:51
Thank you very much Walter!Blushing BigGrin
#1099 Posted : 08 August 2019 22:58:43
Well its been a couple of weeks since my last post. During that time whilst laying the mahogany decking on the lower deck, I noticed that some of the strips weren't as neat as they should of been, so I removed these and made some more. Plus I spent a few evenings not doing any modelling and just chilled, watching random stuff on YouTube.
Suffice to say that the mahogany decking is now complete on the lower deck with just the tiniest amount of trimming to do; should take a couple of hours next week to complete.
#1100 Posted : 08 August 2019 23:00:46
A bit more trimming of the strips around the water-tight ammunition canisters so they sit flush to the deck; although you can't tell from the attached photo.
This page was generated in 0.414 seconds.
