13 Pages <12345>»
Micks 1/200 battleship bismarck Options
#41 Posted : 25 July 2019 18:19:22
Issue 20
Here we get another section of the hull,this is attached to the section previously built,then this is attached to the hull previously built. I left the 2 couplers slightly loose when fixing first to the hull to allow movement to get everything in line before doing up all 4 screws.cheers mick.BigGrin
#42 Posted : 25 July 2019 18:36:36
Issue 21
Here we get first bit of forward superstructure and lots of bits to attach to it , first screw the bit of deck on,then glue the protective walls on, then 2 small skylights inside of these, then 4 barrelled containners in front of the walls, pay attention to the direction of detail on these, then it's rain guards doors and lockers to the side. Best to cut these off one at a time, so don't mix them up, again attention is needed to get these the right way around,I was going to drill out the portholes but the plastic behind is in the way,so elected to paint them black , I'll drop bit of clear pva in these later to make them look glazed,just not got any at the mo . Cheers mick BigGrin
#43 Posted : 25 July 2019 18:45:37
Issue 22
Here we get the 4th section of upper deck we attach the barbettes for the secondary guns,and the fix this bit to the previous bit of deck,as you can see underneath there is a lot of holes for forthcoming electrics to be fitted,as the secondary guns also rotate, then just final shot of what got so far,till next time that's me up to date now.cheers mick. BigGrin
#44 Posted : 25 July 2019 19:31:33
Mick
Had forgotton you were doing this one as well.
You are certainly well ahead on yours.
I think you are getting close to a couple of deck parts i will be interested to see. From ehat i can make out in the advance pictures on the German site they look a little under par with the rest of things. Might be my eyes but interested to see what you and Gray make of them.
Its the parts 29-02 and 29-03 you can see here in issue 29
https://bismarck-bauen.d.../06/29-Bauanleitung.pdf
Think its supposed to represent the non slip lino type material.
tony
#45 Posted : 25 July 2019 20:16:00
Hi Tony looks like some kind of wooden grating on the deck here,be couple months before get them so have to see,so far all can say is the quality is very good ,cheers mick.BigGrin
#46 Posted : 25 July 2019 21:59:05
Very neat and accurate work there Mick. Looking good!Love
#47 Posted : 25 July 2019 23:11:19
Making good progress there Mick, looking good....Cool Cool
#48 Posted : 26 July 2019 09:30:55
Coming along nicely MickThumpUp
#49 Posted : 26 July 2019 14:54:34
Cannot disagree with you on that Mick. I am only at issue 14 but now their earlier delivery issues appear to have been sorted i am tempted to make a start this weekend. Depends if i get a set of countach parts though as that was charged a few days ago.
#50 Posted : 30 July 2019 12:31:54
BigGrin Hi Mick was just wondering if your foredeck decals have arrived yet?
Cheers Gray
#51 Posted : 30 July 2019 15:47:53
Hi Gray not as yet ,but no hurry now I'll be off models couple months now as I have broken my shoulder blade yesterday ,look forward to following your diary though ,and I'll catch up when I can.cheers mick.BigGrin
#52 Posted : 30 July 2019 16:00:57
Crying Oh no, that's not good Mick.
Get well soon ThumpUp
#53 Posted : 30 July 2019 23:52:30
Not good Mick, hope you make a speedy recovery....Crying Crying
#54 Posted : 31 July 2019 07:24:48
Coming oblong very nicely. Sorry to hear about your shoulder, hope your back up and running very soon.Cool
#55 Posted : 28 September 2019 12:38:24
Hi thanks to all who looked in and left comments much appreciated, back on this
Issue 23
Here we attach another hull plate, fit superstructure deck sections together,and add various detail parts together.i painted the portholes in black as I go on this build. Cheers mick BigGrin
#56 Posted : 28 September 2019 12:45:36
Issue 24
Here we get 2 more bits of superstructure deck,these are screwed together, few more details added,then attached to the previous bit of deck we got earlier. Cheers mick BigGrin
#57 Posted : 28 September 2019 12:50:40
Issue 25
Here we get another hull plate to attach, and glue on 2 lifebouys, nice quick issue this one.cheers mick BigGrin
#58 Posted : 28 September 2019 13:00:30
Issue 26
Here we get a forward bit of the superstructure, which we attach various details to, then glue on the fire hoses to the previous bit of superstructure supplied,and put in the bulb for the first navigation light.cheers mick.BigGrin
#59 Posted : 28 September 2019 13:01:34
Issue 26
Here we get a forward bit of the superstructure, which we attach various details to, then glue on the fire hoses to the previous bit of superstructure supplied,and put in the bulb for the first navigation light.we also get a nice engraved plaque. Cheers mick BigGrin
#60 Posted : 28 September 2019 13:07:28
Issue 27
Here we get another hull plate to fix to the hull, and install the second navigation light bulb.cheers mick BigGrin
13 Pages <12345>»
This page was generated in 0.292 seconds.
