 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,192 Points: 15,725 Location: ipswich
Thanks for peeping in chaps. A tiny bit more on this one... roymattblack attached the following image(s):
Looking good Roy, another excellent update.... Regards Alan
Oooo...that looks good. Malc.
Nice eye catching red on that one Roy. Always like Red or the black and white finishes on cars. Tony Happy Modelling
Time to pull this one back out of the pile. Excuse the dodgy image - red is a real pain to photograph... roymattblack attached the following image(s):
 Rank: Amateur Level 1  Groups: Registered
Joined: 25/08/2019 Posts: 31 Points: 93 Location: Texas, USA
Go for it, Roy! Looks like a real winner to me even if it is just a test bed.... Kit builder fanatic! Awaiting arrival: Jaguar E-Type and Suzuki GSX 1300R Hayabusa Received: Lamborghini Countach 500S - build in progress; Shelby Mustang GT-500 build on hold need Pack 9
Just can't get used to seeing those right drive models.... Kit builder fanatic! Awaiting arrival: Jaguar E-Type and Suzuki GSX 1300R Hayabusa Received: Lamborghini Countach 500S - build in progress; Shelby Mustang GT-500 build on hold need Pack 9
Slowly creeping along with this one, among other stuff... Some wiring added, a battery, brake master cylinder and some pipework. Who knows - at this rate I might even finish it before 2020 is out... lol. roymattblack attached the following image(s):
Nothing wrong with taking your time Roy between other builds. Nice work. Mark Regards Markwarren (Mark) Admin
A craftsman never rushes his work Roy and you are certainly a craftsman, looks stunning.... Regards Alan
Many thanks you chaps. A bit more today. Fluid reservoirs are in - a different location to many E Types but that's where they are in this particular car. A bit more metal pipework, and the engine now has a set of Weber carbs although I wont add the air trumpets until later as they would be easily broken off again. The engine isn't actually installed yet as there's more to do to it first. I'm getting determined to see this one off well before Xmas. I've got a few other projects sitting on the back burner I'm quite keen to start but I don't like to have too many things on the go at once. roymattblack attached the following image(s):
That engine is awesome - great job!! Kit builder fanatic! Awaiting arrival: Jaguar E-Type and Suzuki GSX 1300R Hayabusa Received: Lamborghini Countach 500S - build in progress; Shelby Mustang GT-500 build on hold need Pack 9
More done on this one. I've added ignition leads, the wiring block on the cam cover, oil lines and side filter and the front chassis frames. I made the cross tube from brass tube as the kit part is just wonky 'oval' plastic. I still need to add the fuel line to the carbs and some detail around there, as well as the radiator, steering rack and header tanks next. On we go. roymattblack attached the following image(s):
 Rank: Pro Groups: Registered
Joined: 25/02/2017 Posts: 340 Points: 1,019 Location: surrey
Just gets better and better as time goes on. Well done. Andy.
Thanks Andy. I've now sorted the radiator to look more like the one in the real car. Strangely, it seems to be all polished ally except for the actual core and fan shroud. Anyway - that's how it is. I'm now also looking at fitting the door skins to the hinges. I've built enough of these big Revell kits to know by now that the doors NEVER fit - and that's even with the kit coupe rear. The fact I've added my own roadster tail has made it worse. There are gaps along the rear of the door edge that need building up a bit. To do this, I pressed the ends of the door skins into Plasticine and cast the parts in resin. I've added thin plasticard to the backs of the door skins and this will be trimmed back to make a support step for the resin parts. Eventually, I'll trim the parts to the correct length, hopefully to get the doors to be a nice fit, and then I'll sand down the join. With any luck, the added part won't show... roymattblack attached the following image(s):
Very nice work Roy, I’m sure they will fit nicely. Mark Regards Markwarren (Mark) Admin
 All looking good and nice work Roy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Many thanks for looking in you chaps. I've now sorted the door gap issue pretty much. The fault came mainly through my own mis-alignment of the roadster tail when it was bonded to the floor section. I've no idea how, as I measured umpteen times with the door skins taped to the front scuttle section so the tail would be in the correct place. Even so, it seems I mounted it about 1.5mm too far back. Not a lot you might say, but enough to give me a big gap at the rear of the doors. It was sorted by gluing a thin strip of plastic sheet on the reverse of the door edge to act as a joining strip. Before that, I had pressed the end of each door into a slab of plasticine, and cast two door ends in resin. When they were set they were cleaned up and bonded to the door ends. Again, after setting hard the joins were filled and cleaned up. I deliberately made the new edges far too long so I would have plenty to work with getting them the correct length. Now I have doors that fit - they still need painting. The engine has moved ahead with the header tank, coil, intake trumpets and more wiring added. Interior work next... roymattblack attached the following image(s):
Nice recovery! The gap now looks great with your fix! Kit builder fanatic! Awaiting arrival: Jaguar E-Type and Suzuki GSX 1300R Hayabusa Received: Lamborghini Countach 500S - build in progress; Shelby Mustang GT-500 build on hold need Pack 9
Many thanks. The doors now have paint and heve been tested for fit but they won't be attached until more of the interior is sorted. Roy. roymattblack attached the following image(s):
