 Rank: Pro  Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
Pack 8 After sanding the finished planking smooth, the stem, beak, stern post and keel sections were fitted. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Joined: 25/01/2019 Posts: 48 Points: 177 Location: Texas, USA
Wow, looks great Mark! 73 de John W1XQ (ham radio operator) Amateur Radio Lighthouse Society Operator aboard Museum Ship USS Stewart and USS Cavalla
Current attempt: Soleil Royal Prior Builds: Nantucket Lightship, South Goodwin Light vessel, Natchez Packet Paddlewheeler, Souhern Belle Paddlewheel Towboat
Pack 8 Fitted the 3 molding strips to the hull. The Prow was then fitted. I also built and planked the upper, middle and lower stern gallery decks. Thanks for all the kind comments Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Wow! That hull is looking great!Greetings, Walter
Pack 8 Next, I fabricated the hinges and attached the rudder. The 2 Haweses were then built and installed on either side of the prow. 2 x 4 stripes were fitted along the edges of the decks. The molding just below the upper gun ports was added. Made the 2 catheads and fitted them to the forward corners of the forecastle deck. That's it for now. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Mark That looks fantastic. You made such a nice job of the hull - just been looking at the pictures again. Tony Happy Modelling
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Great job of planking the hull I quite like the variations in the wood ,it makes them look like individual planks Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Making great progress and a pleasure to watch.... Regards Alan
Thanks for stopping by and for your kind comments. I can't wait to start fitting the decks. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 8 I retrieved all of the rails and columns I've built so far. Drove a nail in the bottom of each of the outside posts of each rail and the columns. I then cut off the nail heads to create spikes to hold the fixtures on deck. The 65mm rails and 3 columns were fitted to the forecastle deck. The rest of the longer rails and last of the columns were installed on the deck just aft of the main mast hole. That's all for now. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 8 Built the 2 heads. I have to say that I don't care for the brass strips provided for the head bands. The material is difficult to work with and extremely hard to glue in place. They will be fitted later. Next I assembled the beakshead. Made the 20 rungs of the bow bulkhead ladders and glued them in place. Moving on... Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 8 I made half of the gun port doors. 8 small columns were built. The beakshead was fitted and glued to the bow deck and the prow. THIS COMPLETES PACK 8I'll be back in about 2 weeks. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Mark some very nice work again on your build. Tony Happy Modelling
Joined: 08/03/2018 Posts: 11 Points: 39 Location: Bristol
Amazing build, very nice attention to details. Looking forward to see more updates Mark. It helps me a lot since I'm just an issue behind you.
Regards, Oliver.
Certainly powering ahead Mark and making excellent progress too. Keep going like this and you'll end up with a stunning build..... very well done.... Regards Alan
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,864 Points: 20,909 Location: Northamptonshire, England
Great build Mark,  I admire anyone building these kits Very nice work. Mark Regards Markwarren (Mark) Admin
Wonderful build so far, Mark!Greetings, Walter
Pack 9 - Stage 92 In this stage I built Some of the gun port doors. They were painted red on the inside and stained walnut on the outside. A ladder was assembled and cut into 2 sections, each 4 rungs tall. They were fitted to the mid deck leading to the gunwales. mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 9 - Stage 93 This stage found me building the rail along the midship gunwales. 2x7mm walnut strips and 14 brass columns were used. 2x2mm molding strips were added fore and aft of the bottom rail. The top rail ran from the catshead to just in front of the first round gun port. Fitting out the decks is my second most favorite part of ship modeling. (First is actually rigging) mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Looking good, lovely work.... Regards Alan
