T 72 tank Options
Knko
#1 Posted : 20 July 2019 15:31:59
Rank: Newbie
Hi anyone out there who can help I had a problem with starting my tank but the read about b and c wires swapping over that has know worked but cannot get the side tracks to work so as you look from the rear its on the right any advice thanks.
#2 Posted : 20 July 2019 18:19:18
Hi Can you double check all your connections are good , check for bent pins and loose wires.
Knko
#3 Posted : 20 July 2019 19:10:49
Rank: Newbie
Hi thank you for responding I've checked them but I've found that when you push the right controller nothing happens I've also swapped over b and c as it wasn't working at all.
#4 Posted : 20 July 2019 19:24:39
Have you downloaded the app to see if the app will run the tracks, if your tank works with the app then the controller is faulty. Contact C/S for a replacement.
Knko
#5 Posted : 20 July 2019 19:38:28
Rank: Newbie
OK I'll try that
Knko
#6 Posted : 03 August 2019 07:09:10
Rank: Newbie
Can anyone advise how many track links there should be as I cannot connect the track up.
#7 Posted : 03 August 2019 08:12:57
IF you make up the tracks as per the instructions you should have two sets of tracks the same length that will fit the wheels.
