T 72 tank Options
Knko
#1 Posted : 20 July 2019 15:31:59
Rank: Newbie
Hi anyone out there who can help I had a problem with starting my tank but the read about b and c wires swapping over that has know worked but cannot get the side tracks to work so as you look from the rear its on the right any advice thanks.
#2 Posted : 20 July 2019 18:19:18
Hi Can you double check all your connections are good , check for bent pins and loose wires.
Knko
#3 Posted : 20 July 2019 19:10:49
Rank: Newbie
Hi thank you for responding I've checked them but I've found that when you push the right controller nothing happens I've also swapped over b and c as it wasn't working at all.
#4 Posted : 20 July 2019 19:24:39
Have you downloaded the app to see if the app will run the tracks, if your tank works with the app then the controller is faulty. Contact C/S for a replacement.
Knko
#5 Posted : 20 July 2019 19:38:28
Rank: Newbie
OK I'll try that
Knko
#6 Posted : 03 August 2019 07:09:10
Rank: Newbie
Can anyone advise how many track links there should be as I cannot connect the track up.
#7 Posted : 03 August 2019 08:12:57
IF you make up the tracks as per the instructions you should have two sets of tracks the same length that will fit the wheels.
This page was generated in 0.135 seconds.
