Coming together very nice, just shows how intricate this model is. Mark Regards Markwarren (Mark) Admin
Looks spot on. WTG You get a great sense of achievement when you finish this kit. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,185 Points: 15,704 Location: ipswich
That is looking really great. Making all those seats must have been fun...! Will the interior be accessible when the model is finished? It would be a shame if you can't see it all.
Roy.
 Rank: Pro  Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
roymattblack wrote:That is looking really great. Making all those seats must have been fun...! Will the interior be accessible when the model is finished? It would be a shame if you can't see it all.
Roy. The top of the passenger cabin is lift off so the interior is visible. Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Thanks all, for your kind words. This kit is a blast to build. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
I have a question about the lighting kit. I have not been able to find the instructions to connect the power pack to the male power connector. I would be foolish to clad the model without first testing the wiring. I think that the wires should be connected to the plug as i've shown in the attached photo. Am I correct? Thanks Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Hi Mark, Understand where you are coming from with this. The link below will show how the power socket is wired, with the positive on the centre pin and the negative on the outer sleeve. Looking at your pic it looks good that you have the supply plug the correct way round. https://forum.model-spac...spx?g=posts&t=17729
Follow the instructions for the wiring and led`s inside the plane to the letter and you should have no issues. Any worries then post or PM me and we can talk it through. NOTE: When you twist wires together they must be soldered and then covered with heat shrink. You don`t want them coming apart after you have panelled it and have no access.Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Hi Mark, Understand where you are coming from with this. The link below will show how the power socket is wired, with the positive on the centre pin and the negative on the outer sleeve. Looking at your pic it looks good that you have the supply plug the correct way round. https://forum.model-spac...spx?g=posts&t=17729
Follow the instructions for the wiring and led`s inside the plane to the letter and you should have no issues. Any worries then post or PM me and we can talk it through. NOTE: When you twist wires together they must be soldered and then covered with heat shrink. You don`t want them coming apart after you have panelled it and have no access.Regards delboy271155 (Derek) Thanks Derek, appreciate your assist Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 6 Got the lighting kit power connection and lines for each wing and tail fitted. I tested the installation and found a bad solder joint on the connector. I'm so glad that I went "off Book" and tested the wiring. I would have been thoroughly Puted  had I buttoned it up and later found out that the optional lighting kit that I had to order from the UK site and have it shipped internationally at a total cost of $75 US (cost of part, shipping and conversion from USD to British pound). Thanks for stopping by, Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 6 The last step to pack 6 is cladding the outside. I did not have any masking or painting to do as I painted the preformed metal parts at the time i installed them. This completes Pack 6. Thanks for looking in. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Its looking great.Good to see a US build of this.I was at an airshow this weekend and thye had a whole line of C47s on display.Awesome planes
Mark Well done on testing the lighting and fixing that fault. Tony Happy Modelling
Pack 7 Pack 7 is the tail section of the aircraft. It is pretty straightforward construction so I will let the pics do the talking. Thanks for following Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
darbyvet wrote:Its looking great.Good to see a US build of this.I was at an airshow this weekend and thye had a whole line of C47s on display.Awesome planes
I'm thinking that I might get a second subscription of this kit and modifying the build to create a C 47. It would be a challenge but I think the result would be worth the time Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
mwstratton wrote:darbyvet wrote:Its looking great.Good to see a US build of this.I was at an airshow this weekend and thye had a whole line of C47s on display.Awesome planes
I'm thinking that I might get a second subscription of this kit and modifying the build to create a C 47. It would be a challenge but I think the result would be worth the time Mark Oh yes that would be great.you could take out the seats and put benches in and make a band Of Brothers diorama with some airborne infantry figures. Carl
Pack 7 I've fitted the tail gear mount and built the rudder. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
This is coming on a pace and looking good. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Just catching up with your build Mark. Coming on very nicely. Mark Regards Markwarren (Mark) Admin
You're doing a great job with this one Mark, all looks very good indeed.... Regards Alan
