6 Pages «<3456>
Mark's DC-3 Options
#81 Posted : 18 July 2019 07:14:38
Coming together very nice, just shows how intricate this model is.Love
#82 Posted : 18 July 2019 07:24:21
Looks spot on. WTG
Cool Cool Cool
You get a great sense of achievement when you finish this kit.
Keep up the good work. BigGrin
#83 Posted : 18 July 2019 08:15:30
That is looking really great.
Making all those seats must have been fun...!
Will the interior be accessible when the model is finished?
It would be a shame if you can't see it all.
Roy.
mwstratton
#84 Posted : 18 July 2019 13:57:08
Roy.
The top of the passenger cabin is lift off so the interior is visible.
Under the Bench:
mwstratton
#85 Posted : 18 July 2019 13:58:30
Thanks all, for your kind words. This kit is a blast to build.
Under the Bench:
mwstratton
#86 Posted : 18 July 2019 19:28:05
I have a question about the lighting kit. I have not been able to find the instructions to connect the power pack to the male power connector. I would be foolish to clad the model without first testing the wiring. I think that the wires should be connected to the plug as i've shown in the attached photo. Am I correct?
Thanks
mwstratton attached the following image(s):
Under the Bench:
#87 Posted : 18 July 2019 20:09:21
Hi Mark,
Understand where you are coming from with this.
The link below will show how the power socket is wired, with the positive on the centre pin and the negative on the outer sleeve. Looking at your pic it looks good that you have the supply plug the correct way round.
https://forum.model-spac...spx?g=posts&t=17729
Follow the instructions for the wiring and led`s inside the plane to the letter and you should have no issues.
Any worries then post or PM me and we can talk it through.
NOTE: When you twist wires together they must be soldered and then covered with heat shrink. You don`t want them coming apart after you have panelled it and have no access.
mwstratton
#88 Posted : 18 July 2019 20:37:02
delboy271155 wrote:
Hi Mark,
Thanks Derek, appreciate your assist
Under the Bench:
mwstratton
#89 Posted : 19 July 2019 01:48:35
Pack 6
Got the lighting kit power connection and lines for each wing and tail fitted. I tested the installation and found a bad solder joint on the connector. I'm so glad that I went "off Book" and tested the wiring. I would have been thoroughly Puted Cursing had I buttoned it up and later found out that the optional lighting kit that I had to order from the UK site and have it shipped internationally at a total cost of $75 US (cost of part, shipping and conversion from USD to British pound). Blink LOL
Thanks for stopping by,
Under the Bench:
mwstratton
#90 Posted : 19 July 2019 01:53:11
Pack 6
The last step to pack 6 is cladding the outside. I did not have any masking or painting to do as I painted the preformed metal parts at the time i installed them.
This completes Pack 6.
Thanks for looking in.
Under the Bench:
#91 Posted : 19 July 2019 02:35:44
Its looking great.Good to see a US build of this.I was at an airshow this weekend and thye had a whole line of C47s on display.Awesome planes
#92 Posted : 19 July 2019 07:15:09
Well done on testing the lighting and fixing that fault.
#93 Posted : 19 July 2019 11:19:09
Looking good Mark and making nice progress with your build, thanks for sharing. Glad you decided to test the electrics before sealing it all up, that would have been such a shame to find that the lighting didn't work, besides being extremely frustrating for you!?
Well done. Cool ThumpUp
mwstratton
#94 Posted : 02 August 2019 20:12:53
Pack 7
Pack 7 is the tail section of the aircraft. It is pretty straightforward construction so I will let the pics do the talking.
Thanks for following
Under the Bench:
mwstratton
#95 Posted : 02 August 2019 20:18:33
I'm thinking that I might get a second subscription of this kit and modifying the build to create a C 47. It would be a challenge but I think the result would be worth the time
Under the Bench:
#96 Posted : 02 August 2019 20:25:26
Oh yes that would be great.you could take out the seats and put benches in and make a band Of Brothers diorama with some airborne infantry figures.
mwstratton
#97 Posted : 03 August 2019 05:33:37
Pack 7
I've fitted the tail gear mount and built the rudder.
Under the Bench:
#98 Posted : 03 August 2019 07:58:23
This is coming on a pace and looking good.
Cool Cool Cool
#99 Posted : 03 August 2019 09:07:50
Just catching up with your build Mark. Coming on very nicely.Love Drool
#100 Posted : 03 August 2019 22:41:34
You're doing a great job with this one Mark, all looks very good indeed....Cool Cool
6 Pages «<3456>
This page was generated in 0.385 seconds.
