you are really steaming through this build and it looks perfect as usual.
 Thanks for looking in and your comments Carl Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 The three guns have been made up and painted in the next picture you can see the lower gun mount position at the rear gunners position. Once the gun was positioned on its pivot point I made a circular pad from plasticard and glued it to the bottom of the gun mount this keeps the gun fixed but also allows it to traverse. The Cockpit was next mounted onto the fuselage side and the bottom glass panel that opens so the lower rear gun can be fired added and then the other half of the fuselage was glued to the first half. Next the molded lacing was added at the rear of the bottom fuselage hiding the joint here and the rear bomb bay deck added with more molded lacing. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Andy, going to look fab when finished I'm sure.... Regards Alan
 Thanks for looking in and your comments Alan. A lot of shiny dark blue goes on next as a base for the decals to sit on Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks like a real nice kit to put together and its coming on nicely. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
They are great kits, you are certainly doing this justice, great work Andy. Mark Regards Markwarren (Mark) Admin
 Thanks for looking in and your comments both Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 The fuselage and lower wing centre has been undercoated and then sprayed with Tamiya Sea Blue which is more a dark green blue. When dry a couple of coats of gloss varnish will go on as a base for the lozenge camo decals. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Watching very closely Andy and studying your techniques to see what I can pilfer.....  .. Looks great as always.... Regards Alan
 Thanks for looking in and your comments Kev Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great work Andy, I’m watching with interest too. Mark Regards Markwarren (Mark) Admin
eagerly awaiting the lozenge decals.Looking great so far.
 Spent most of today getting the lozenge decals placed on the fuselage and lower centre wing. Now to let them dry out overnight and then more decals can be placed on top of them. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Like the effect the decals give, looks great..... Regards Alan
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,188 Points: 15,713 Location: ipswich
I'm not normally a 'wingy-thing' person but this really looks great.
I'll even be starting on a Sopwith Camel at some stage soon. I'll be looking here frequently to see how an aircraft is built properly...
Very nice work Andy, you’ve done an amazing job on that so far. Mark Regards Markwarren (Mark) Admin
 Thanks for looking in and your comments everyone Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
