Thanks admin, Phil, appreciate the kind comments.... @admin - the interruptions were taken as a blessing, gave me a break from the tedious task of lining all those ports..... Regards Alan
Stage 103 Contents: Mast Top and parts fret, Gallery Roof and Decorations.
Cut a length of 0.5 x 4mm wooden strip (Stage 84) to fit over the central door at the aft end of the quarterdeck. Glue to one side of the centre line, using the decking planks as a guide. Cut a second length of strip and glue it next to the first, on the other side of the centre line. Continue fitting lengths of strip to completely cover the top of the door. When dry, cut the ends of the strips so they are flush with the front and back of the doorway. Cut another length of wooden strip to fit over the back of the doorway and glue it into place. When dry, cut the excess of the strip away and sand the doorway roof smooth. Now repeat the process on the two doorways at the front of the quarterdeck.
Retrieve the two roofs C63 from stages 37 and 39, glue them over the walls of the doorway at the aft end of the main deck.
Note: As I’m using wood stain, I chose now to stain the forward sections of the bow decks with two coats of natural oak. This helped to prevent the possibility of any stain bleeding onto the deck when staining the forward bulkhead. Once dry, the forward bulkhead was then stained using the same stain as on the main hull.
Take the two door frames 125 and 140 (Stage 69), glue them to the front of the bulkhead 15mm from either side of the centre line.
Remove the parts from the mast top fret and sand the edges smooth. Note: The staining/painting of the fighting top was completed as outlined in build stage 95 so won’t be repeated here. Test-fit and glue one of the crosstrees into the first notches of the two trestletrees, checking they are perpendicular. Test-fit and glue the other two crosstrees into the other notches of the trestletrees. Before the glue dries, check that they are all at right angles.
Test-fit and glue the 12 ribs into the notches in the mast top platform. Now glue the rail onto the tops of the ribs. Turn the platform over and glue the crosstrees onto the underside, ensuring it is centred and has the correct orientation as shown in step 16 of the instructions.
Retrieve decorations C142, C142a, C142b and C142c from stage 102, Remove any burrs or flash and apply a coat of metal primer, leave to dry.
Follow the painting guide provided within the instructions to paint the decorations. When dry, carefully store the decorations in a bag labelled with this stage number.
Store the mast top assembly and any unused parts in a bag labeled with this stage number.
This stage is now complete.Gandale attached the following image(s):
Beautiful work as always Alan. A true craftsman. Marki Regards Markwarren (Mark) Admin
Great work again Alan I keep coming back to look at this build. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 A joy to watch & follow, Alan
 All looking good and nice work from you as always Alan Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,195 Points: 15,734 Location: ipswich
Lovely work there. This is going to be a fantastic piece when you've completed it - it already is.
Great update and great build!Greetings, Walter
All looking very impressive Alan. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Great stuff Alan . Will this go back to being the official guide now? If not then it should be Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Thanks for all the kind comments guys, appreciated as always.... @ Nightwisher - Yes, this will be moved over to the Official Build topic in due course but in the meantime it will continue here..... Regards Alan
Thanks Kev, appreciated.....  .. A great deal of decorations still to be painted before we get to the end.... [cool... Regards Alan
Stage 104 Contents: Gallery Roof and Decorations.
Retrieve decorations C143, C143a, C143b and C143c from stage 103, Remove any burrs or flash and apply a coat of metal primer, leave to dry. Follow the painting guide provided within the instructions to paint the decorations. When dry, carefully store the decorations in a bag labelled with this stage number.
Apply some modelling putty/filler to the joins between the bow door frames and the bow wall. I used a dark colour wood filler for this task. Leave the filler to dry then smooth the joins with sandpaper.
Now apply filler around the two doorways at the rear of the main deck. Leave to dry then sand the area smooth. Now mask off and paint the areas around the bulkheads red (RAL 3020).
Note: I chose to hold off from painting any of the door frames at this stage, they will be painted when the decks have been finished and sealed.
Store any unused parts in a bag labelled with this stage number.
Lovely work as usual Alan, you are a dab hand at painting those decorations. Mark Regards Markwarren (Mark) Admin
Beautiful work Alan. Accurate and neat. This is going to be a show stopper when done! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks guys, appreciate the kind comments and support.... More to come soon but have a couple of decisions to make first..... Regards Alan
 Coming together very nicely now Alan and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Alan That looks fantastic and your painting is just so neat. I bet there is a fair weight to this one with all those castings you have to add. Its a great looking model for sure. Tony Happy Modelling
Fantastic update!Greetings, Walter
Guest (5)
