Than you everyone for looking in and your comments.  I’m only halfway through pack 11, loads do do in this one. Mark Regards Markwarren (Mark) Admin
Looks a really good kit Mark, and coming together well
Cheers Gray
Thank you Gray for you comments. Still completing pack 11. As I said a lot of work to do in this part of the build and quite honestly you need three pairs of hands on some parts to fit. I did run into a couple of issues along the way, one of which was my own doing.  I had difficulty fixing the rear exhaust pipe to the engine block, it just didn’t sit right which meant I couldn’t attach the bracket on the frame in the right place. After several hours I found the problem. In the first picture you will see that the ball end is not seated correctly into the top section with the pin not fitting into the slot. Once this was rectified, hey presto, it fitted correctly. The other issue was that the instruction showing the rear footrest fitting behind the exhaust, when in fact they should fit in front. You don’t want the rear passenger burning his/her foot on the exhaust pipe. The next lot of pictures show how and where they were altered. An easy fix. I have just fitted the front forks and now finishing off the cables This is quite a beast of a kit, I will show more pictures later. Now where is that wide angle camera. Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
 All looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Superb work Mark  good spot with the footrests. Al
They put one heck of a lot of detail into this kit when they designed it Mark. The more i seeof this one the more its growing on me and you seem to be getting more build per instalment on this one. Tony Happy Modelling
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,188 Points: 15,713 Location: ipswich
You really are taking great care with this one. That's what lifts a model into the next level. Keep it coming - a fascinating build.
Roy.
Many thanks guys for the comments. I have finally finished pack 11, and as luck would have it, the postman bought the final pack 12 this morning. So, I set to fixing the clutch and throttle cables to the handlebars. As you can see in these pictures it is some size. Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Pack 12 In the final pack we get to fit spark plugs all the cabling and pipework as well as fit the seat and front tank. You also got to change some of the screws fitted in earlier stages with the proper bolts, which is a nice touch. Finally, I then gave the chrome my oil treatment to take off the highly, too shiny, chrome plating to give it a more authentic look. The final pictures are of the Captain America complete. It has been a pleasure building this, although frustrating at time, but this is a well detailed kit and looks absolutely stunning to look at. I will be posting the final gallery pictures shortly with the helmet attached as well. Thanks all for looking and following this build. Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Looks huge Mark, my question would be where are you going to be able to display this beast....  .. Beautiful build and credit to your skills.... Regards Alan
Gandale wrote:Looks huge Mark, my question would be where are you going to be able to display this beast....  .. Beautiful build and credit to your skills.... Regards Alan Thank you Alan. Not sure where it will go just yet, think I need a bigger house. Mark Regards Markwarren (Mark) Admin
Very nice Mark. Looks absolutely superb! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
looks fantastic.Put on some Springsteen and blast "Born in the USA" as loud as you can!!
darbyvet wrote:looks fantastic.Put on some Springsteen and blast "Born in the USA" as loud as you can!!
 Or better still 'Born to be Wild' by Steppenwolf Great result Mark Cheers Gray
 Rank: Beginner Level 3  Groups: Registered
what a stunning model, it just keeps getting better casp
Wish I had the space for this one it looks stunning. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
