Samba interior Options
andali15
#1 Posted : 08 July 2019 17:57:29
Hi guys, building the Samba I’m thinking I would like to put colour on the seating. Looking at life sized Sambas there seems to be a lot having the centre panels of the seating the same as the exterior colour. Not sure best way to do it as the seating is of a soft rubber consistantcy. Any ideas would be helpful. Main concern would be if I mess up would I be able to get replacements as this build is not on a weekly buy. Andy.
#2 Posted : 08 July 2019 18:42:46
Initial thought would be some thing along the lines of a self adhesive material and if its a vinyl type finish you are after what about some sort of sticky backed plastic - the old fablon type product for example?
That would allow you to remove it if you did not like the result.
andali15
#3 Posted : 08 July 2019 19:09:10
Yes worth a try Tony. Seating being soft , paint may crack if pressed. Some experimenting to be done. Andy.
experten
#4 Posted : 09 July 2019 01:04:30
Perhaps consider a fabric paint? Of necessity, they are flexible.
Tired, Old, and Cranky!
andali15
#5 Posted : 09 July 2019 07:06:37
Hadn’t thought of fabric paint experten thanks for the suggestion. Andy.
#6 Posted : 09 July 2019 08:18:35
How about panels of very thin leather backed with D/S tape?
I will conform to the seat shape easily and will then give the look of half-leather trim...
Roy.
andali15
#7 Posted : 09 July 2019 11:59:47
Like the sound of leather Roy. Your builds always look great with leather seating. Cheers for the idea. Andy.
This page was generated in 0.097 seconds.
