4 Pages <1234>
Another lightweight E Type build Options
#21 Posted : 22 June 2019 11:12:55
Thanks Alan. I need to get a bit of a move on though.
Projects are piling up...
#22 Posted : 23 June 2019 09:40:29
Very nice work Roy.Love
#23 Posted : 23 June 2019 11:46:25
Superb work RoyDrool do you make these in your dreams as wellLOL LOL LOL regards PhilCool
#24 Posted : 24 June 2019 13:18:53
More like my nightmares Phil - lol.
Anyway, front cradle now sorted and all in primer.
This whole area under the bonnet (hood) will be satin black, as it is on the real car.
Actual body, bright red...
On we go.
#25 Posted : 25 June 2019 21:01:17
First bit of major filler on the body joins now rubbed down, and another coat of primer so I can see where more work is needed.
#26 Posted : 26 June 2019 09:44:46
Very impressive as always Roy.
#27 Posted : 15 July 2019 11:46:33
Back on with this one for a while so I've given the front frame and firewall area a coat of satin black.
The actual car I'm making has this area in black even though the rest of the car is bright red.
Once dry, I'll mask it off and prepare the body for a full coat of white primer followed by the red.
#28 Posted : 15 July 2019 16:02:02
Great work Roy, nice to see a master at work.Love
#29 Posted : 15 July 2019 16:45:14
I read that too quickly - I thought it said MONSTER at work... lolLOL LOL LOL
Many thanks though.
#30 Posted : 15 July 2019 20:38:01
Looking good Roy, well done. ThumpUp
#31 Posted : 15 July 2019 21:33:17
Steady progress Roy, looking fab.....Drool Drool
#32 Posted : 16 July 2019 10:29:36
Many thanks chaps.
I've masked off the front frame and interior and now the body has a few coats of white primer.
This shows up flaws, 'dimples' , dents etc that need to be attended to before another coat of primer.
Then a fine rub down and eventually, some body colour...
Edit - forgot to add the boot air vent - now sorted.
#33 Posted : 16 July 2019 14:07:08
Looking good Roy.
#34 Posted : 17 July 2019 08:27:41
The car had a good 24 hours for the primer to dry, then a fine sanding all over with 1200 grit wet and dry.
A really good dusting and brushing and then the red went on.
2 base coats, 15 mins between each, and then 2 'flood' coats, again 15 mins between each.
I use Halfords car paints as they work so well on large models.
When dry, a bit of a buffing.
I don't think I'll use a clear coat as I always think it looks a bit 'too' glossy, but it depends how the red dries out...
Apologies for the images - reds always look a bit peculiar when taken indoors using flash...
#35 Posted : 17 July 2019 10:17:26
Well, now unwrapped from the masking and a base coat of satin black on the interior rear wall.
These areas will eventually be covered with thin black rubber sheet so the black is only really needed at the edges etc to cover any possible gaps in the rubber.
I'll leave it alone now for the rest of the day to let the red harden a bit more.
Roy.
#36 Posted : 17 July 2019 22:39:05
Very nice work Roy. The first lot of pictures I had to wear my sunglasses.LOL
#37 Posted : 18 July 2019 08:12:59
Thanks Mark.
Red is always a pain with digital photo's.
Roy.
#38 Posted : 18 July 2019 22:11:06
Really enjoying seeing you work on this and the process you go through Roy, looking fab.....Drool Drool
#39 Posted : 19 July 2019 08:37:53
Many thanks for looking in on my waffle you chaps.
The dash I have is LHD.
The actual car is RHD so it needs changing over.
The dash support panel had to be cut on both sides and the steering column section swapped over. All quite simple.
I cast a new racing RHD dash in resin and that is now in place with new race gauge decals.
A little bit I couldn't resist at this early stage - the vent holes in the boot lid.
Roy.
#40 Posted : 19 July 2019 11:12:44
Nicely done Roy, the dash looks great! ThumpUp
4 Pages <1234>
This page was generated in 0.249 seconds.
