4 Pages <1234>
Hatchets Build the Bismarck Options
#21 Posted : 07 August 2011 22:58:06
Thank you Ian Good infoBigGrin
#22 Posted : 07 August 2011 23:11:09
I Think that it would be viable for the hood might just need a bit of upgrading round stern where rudder tubes go through hull and you would have to make some slightly larger rudders and probably working out some way of moddifying access trough upper decks by making them removable. Ian
#23 Posted : 07 August 2011 23:29:11
Great stuff lets do itBigGrin
budgie
#24 Posted : 08 August 2011 00:58:32
Blink don't forget if the superstructure is top heavy you will need hull area to add ballast
What is the superstructure being made from wood with metal etching (as the Bismark) or solid metal?
#25 Posted : 08 August 2011 01:04:35
Hi Budgie,at the moment we do not know, we believe the Hachette Hood is being released on the 24th August, if not we have the Akagi.
#26 Posted : 08 August 2011 01:11:56
hi budgie
yes you are right the hull dose need to ballasted on r/c model
the hood looks like a wish list boat as no one doing it in partwork at the moment Ian
#27 Posted : 08 August 2011 01:27:02
Good night Ian
willie
#28 Posted : 08 August 2011 11:07:11
if you look at the 350 scale rudder on the hood and the 200 scale follows the same diamentions i doht think you will need a bigger rudder she has only one, large one
#29 Posted : 08 August 2011 15:20:32
Thanks for the info Willie
BigGrin
#30 Posted : 08 August 2011 15:25:13
Generally scale rudders on R/C models don't perform well, which is why with the Bismarck R/C version, a larger pair of rudders were supplied with the kit Wink
#31 Posted : 08 August 2011 15:28:07
Very true Mr T
#32 Posted : 09 August 2011 00:13:43
i Have added some pictures of bismarcks sea planes
#33 Posted : 09 August 2011 00:16:20
The detail on the seaplanes is fantastic, Good stuffCool BigGrin
#34 Posted : 09 August 2011 00:18:13
Thanks MikeBigGrin
#35 Posted : 17 August 2011 00:08:22
Hi All
I Have added some more pictures to photo bucket link below
I have just finished spraying and painting
1) main guns
2) remaining various sizes of deck guns
3) sprayed funnel
4) various range finders for upper super structure
Ian
#36 Posted : 17 August 2011 01:04:55
Good job IanBigGrin
Tiswas
#37 Posted : 03 September 2011 21:53:24
[quote=ian smith]Hi All
I Have added some more photos of the construction of the super stuctor and some photos of the radio controll instalation. ian
http://s1188.photobucket.../albums/z411/iansmith3/[/quote]
Great pictures and lovely build. I am also starting to collect parts for the Hood, which will have the R/C option. Seeing your photo's I was wondering about ballast??? is the battery and motor heavy enough do you think to give addiquate buoyancy?
TIS
#38 Posted : 03 September 2011 22:50:13
I would not worry about this at this stage as the series will no doubt provide all you need to know at the relevant point
#39 Posted : 05 September 2011 17:04:33
Thanks for answering the question Mr t . Yes the radio controll
parts of the magazine go into adding ballast ian
[BigGrin ]
#40 Posted : 06 September 2011 22:48:48
Hi Guys
I have added some more photos
the admirals bridge has been fitted, life rafts fitted, various ladders and lockers fitted round decks
4 Pages <1234>
This page was generated in 0.138 seconds.
