Has anyone considered or implemented smoke effects for the D51?
Joined: 14/03/2013 Posts: 43 Points: 129 Location: Calwell ACT AU
Hi, I tested this idea with an old unit from a articulated steamer I picked up at a garage sale. I dropped the idea as it was just too small, it still generated smoke for its age, great for HO scale but nothing larger. Perhaps one designed for model steam boats would suffice. You only live once, but if you work it right, once is enough.
Building - Bismarck, Akagi, Warspite, Gato, USS Enterprise (carrier) and D51
Cornwall model boats have suitable generators available if you want to go down that path, but I agree with Alan in regards to the volume needed to do it justice. You only live once, but if you work it right, once is enough.
