10 Pages «<56789>»
Ant62 victory build Options
#121 Posted : 21 May 2019 21:43:16
Hi Ant62,she is looking good and now you are coming to plank the lower part of the ship and i was wondering if you are going to use filler blocks for the stern and bow as this will help keep the shape of the hull with out the use of additional clamps and will be better formed.
just a thought
Trev.
z8000783
#122 Posted : 22 May 2019 07:18:50
Groups: Unapproved
Ready to go and looking good. You might find this useful when yoy come to lay the last 10 planks.
Last 10 planks
Ant62
#123 Posted : 22 May 2019 10:01:30
just a thought
Trev.
Hi i have not given any thought to planking the hull after i got to the stage where it is now....
But now you have mentioned i will look into it...
Would i be correct in looking at balsa blocks!!!!!
Building.
HMS Victory.....
Corel Albatross 1840......Completed
Hindenberg Zepplin museum piece..Completed
Artesian Latina Sopwith Camel.....Completed
Bismark.........
#124 Posted : 22 May 2019 16:35:18
Hi Ant62 you may find it better to fill the blocks as a loaf of bread standing up type construction,don't pay to much attention to getting the exact shape of the area at this point it is better to have to much material rather than too little as low spots take more time to fix with the use of wood fillers.
Hope this helps
Trev
Ant62
#125 Posted : 22 May 2019 20:38:23
By the Loaf of bread terminology you mean a piece on top of a piece and glue together and then sand to shape....
Building.
HMS Victory.....
Bismark.........
#126 Posted : 22 May 2019 21:30:40
With my Victory build I used expanding foam, the one you get in a tube and chopped it off with a bread knife,best bet would be Balsa and slot it in and sand it down.
You will see that the shape will come to life and that will stop any twisted planks.This will be a matter of choice for you to think on.
Trev
Ant62
#127 Posted : 23 May 2019 07:50:58
Trev
Expanding foam!
That different and something totally unexpected..
What was it like to work with!
My only issue i have with using blocks is that i dont have any sanding equipment its all by hand..
I do have the dremel kit given out by Deagostini but even that im unsure with..
Last time i sanded balsa wood where in school many years ago so havent a clue what its like to work with...
Building.
HMS Victory.....
Bismark.........
#128 Posted : 23 May 2019 18:05:39
Hi Ant62 sent PM with pictures to show what I am saying regarding bow (fitted with balsa)
Trev
Ant62
#129 Posted : 19 June 2019 11:34:01
Since my last post ive only managed 30mins here and there and ive been learning bits at a time..
All the planks in the photo are only pinned in place as you may well suss out..
This is if i see something not right i can have another go....
Ant62 attached the following image(s):
Building.
HMS Victory.....
Bismark.........
Erik A
#130 Posted : 19 June 2019 23:20:13
looking good.
i had mine with the fairing all done and ready to plank then decided to infill with balsa at the bow and the first couple of side frames bow and stern. balsa is easy to sand by hand and doesnt take long at all.
Current builds
HMS Victory
Endeavour longboat
Ant62
#131 Posted : 20 June 2019 11:49:40
I did intend to add balsa to the bow and a couple of side frames but who i buy my limewood strips from had sold out and i where not paying for two lots of delivery..
So when i found out they had some limewood instock and by the time i got online to place my order it had all gone...
Just my luck..
Anyway the planks are only pinned i can still add balsa before i glue any of the planks and make adjustments..
Building.
HMS Victory.....
Bismark.........
z8000783
#132 Posted : 20 June 2019 11:55:40
Groups: Unapproved
It is a nice to do and I will definitely do it on my next build (?) but it is not a necessity. The key here is to have faired the keel properly i.e. if you have any doubt then continue rubbing down or building up until you are fully satisfied that the your test planks look good and run smoothly around the bows.
Ant62
#133 Posted : 20 June 2019 13:49:08
Its all trial an error for me....
Im learning as im going along but i can only do bits here n there due to a new addition the family.....
Building.
HMS Victory.....
Bismark.........
Erik A
#134 Posted : 20 June 2019 21:46:46
lol yeah im struggling to find time to do mine as well. and im in the throws of organising my house getting relocated so will be out of it for 3 weeks as of week after next. i will probably get more time while out of the house as we are staying at my wifes sisters place and i will be hiding in the bedroom as i dont get on with them that well. Blink gonna be the worst 3 weeks ive had in many many years Crying Crying
Current builds
HMS Victory
Endeavour longboat
#135 Posted : 21 June 2019 07:28:57
Hi Ant62
Looking at your build it looks like what is called crowding thats when the planks are to thin at the end resulting in splinter like plank, you may well have to put a few drop planks to reduce the number of planks running forward.
Trev.
Ant62
#136 Posted : 22 June 2019 08:57:50
I bet that wont go down well sneaking off out of the way..
Building.
HMS Victory.....
Bismark.........
Ant62
#137 Posted : 22 June 2019 08:59:17
tf64 wrote:
Hi Ant62
Trev.
I agree....
I did think it was a struggle though....
At least they are not fixed perminently..
Building.
HMS Victory.....
Bismark.........
z8000783
#138 Posted : 22 June 2019 10:41:31
Groups: Unapproved
Have a look at Stage 32 for making dropper planks.
Ant62
#139 Posted : 15 November 2019 14:29:29
Hi all...
Back on the Victory build today...
I had to suspend the subscription due to a temp move while the repairs where carried out on our property and various other issues and hopefully back home by christmas so i can get the boxes back to being delivered but i wont hold my breath...
Anyway im back onto the the planking of the bow with a clear head and boy it does you good to leave the build alone and have clearer thoughts.
So ive managed to bend two bow planks and also do the drop planks etc....
Pics soon..
Building.
HMS Victory.....
Bismark.........
Ant62
#140 Posted : 15 November 2019 20:40:08
Latest picture of todays few hrs on the bow..
Building.
HMS Victory.....
Bismark.........
10 Pages «<56789>»
This page was generated in 0.806 seconds.
