Sticky Wickett wrote:Just caught up with this Alan. Your figure painting is lovely mate. Absolutely top work! Regards, Phil W. Thanks Phil, appreciated.... The painting of all these decorations does get a little tedious at times but has to be done, shame they are so small..... Onwards we go... Regards Alan
Stage 96 Contents: Decorations.
Remove any burrs or flash from the decorations supplied with this stage. Apply a coat of metal primer and leave to dry.
Now retrieve decorations C68b, C68g, C68h, C58j and C58k from stage 80. If you haven’t already done so then remove any burrs or flash from these decorations and apply a coat of metal primer.
Follow the painting guide provided within the instructions to paint all these decorations. When dry, carefully store the decorations in a bag labelled with this stage number, ensuring you can easily identify the two different sets.
This stage is now complete.Gandale attached the following image(s):
Alan Very neat work. They look like they are "trying the builders patience" with some of thosevparts getting smaller it looks like to me. Tony Happy Modelling
birdaj2 wrote:Alan
Very neat work.
Tony Thanks Tony, can only agree with you. Builders will need a great deal of patience when painting all of the decorations, they are small, detailed and never ending. Same image again but this time with the customary penny shot for scale and these are not the smallest..... Regards Alan Gandale attached the following image(s):
 I can only commend your patience and skill Well done Alan
 Lovely work as usual Alan Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Master at work,how many hairs on that paint brush ? Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks guys for the supportive comments, appreciated...... @Trev: Brushes used are tiny and have even pulled some bristles out of brushes on occasions. Biggest thing though is patience and lots of it..... Regards Alan
Stage 97 Contents: Wooden Strips, Gallery Parts and Decorations.
Follow the painting guide provided within the instructions to paint the decorations. When dry, carefully store the decorations in a bag labelled with this stage number.
Stage 98 Contents: Stern Decorations and Wooden Strips.
Now retrieve the four lion head (C20) decorations from stage 89. Note: The instructions do not advise when these decorations are to be painted however, you will need paint these in order to complete this stage. Remove any burrs of flash from these decorations and apply a coat of metal primer. Follow the painting guide in Stage 83 to paint these decorations.
Glue two 1.5x5mm wooden strips together side by side then repeat with another two strips. When the glue has dried, sand any uneven areas of the strips smooth. (I chose to paint (RAL 3020) these strips now). Cut a total of 52 (10x10mm) sections from the strips and paint any unpainted edges.
Take the 0.5x6mm wooden strips and lightly sand them smooth. I chose to stain these strips now using the same stain as was used on the main hull. Glue two wooden strips together side by side then repeat with another two strips. Cut the final strip in half and glue the two halves together side by side. Cut a total of 52 (12x12mm) sections from the strips and touch up any edges where needed.
Glue a 10mm piece into the centre of the 12mm piece, leaving a gap of 1mm on every side. These parts make up the gun port doors. Repeat the process until you 52 doors. Now retrieve the 18 lion head decorations C20 and glue a lion head decoration in the centre of 18 of the prepared gun port doors.
Carefully store the decorations and the gun port doors in a bag labelled with this stage number.
 Cracking job Alan. I have just started doing mine Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Alan You have a lovely consistant finish across the pieces. The lions heads look very neat. Tony Happy Modelling
 All looking good and nice work Alan Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
certainly a colourful ship, your doing a cracking job Alan Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Great work Alan, looking stunning. Mark Regards Markwarren (Mark) Admin
Incredible detail! Top results!Greetings, Walter
Hi Alan, Wonderful job on the painting, that must have took some time, great skill,I can remember painting gunports in my youth on a ship called (Norske-Love) Billing Boats they were the same color red and gold so I know how hard it was for you to paint them. Well done Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Lovely paintwork Alan ,can't wait to see it all in place Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
