10 Pages «<34567>»
Ant62 victory build Options
Ant62
#81 Posted : 07 May 2019 12:58:38
A spare couple of hours this morning so i cracked on with the 2nd deck gun ports and the eventually the entry port...
Just double checking things as i go....
Ant62 attached the following image(s):
Building.
HMS Victory.....
Corel Albatross 1840......Completed
Hindenberg Zepplin museum piece..Completed
Artesian Latina Sopwith Camel.....Completed
Bismark.........
Ant62
#82 Posted : 07 May 2019 15:20:00
When cutting out the bow cannon port after removing the planking how much of the bow behind the planking do i cut back if any...
Building.
HMS Victory.....
Bismark.........
z8000783
#83 Posted : 07 May 2019 15:26:41
Groups: Unapproved
Just enough to fit the gun port lids is all that is necessary since they will be set in the closed position.
Ant62
#84 Posted : 07 May 2019 16:34:08
Thanks....BigGrin
Building.
HMS Victory.....
Bismark.........
Ant62
#85 Posted : 08 May 2019 19:24:34
All the canon ports are a carved out of the middle deck and in doing so i came up with a canon port hole checker...
Some stiff ish plastic is required from something like a packet..
Cut your 12mm x 12mm square.
Make your centre hole...
Get two pieces of plank of cuts about 3inches long and glue them together and clamp...
Once dry get a drawing and push through the square...
Then push it into the end of the two glued planks....
Thn hold upton the hole to get the size....
Building.
HMS Victory.....
Bismark.........
Ant62
#86 Posted : 08 May 2019 19:27:37
Here is a photo of bow..
Building.
HMS Victory.....
Bismark.........
z8000783
#87 Posted : 08 May 2019 19:46:11
Groups: Unapproved
Looks good. On track.
#88 Posted : 08 May 2019 23:57:38
Very neat.
You did well getting all of those gun ports cut in so short a time. Good idea with the size checker as well.
Ant62
#89 Posted : 09 May 2019 14:53:10
birdaj2 wrote:
Very neat.
It helps using the correct tool for the job like the Swann Morton scapel and blades......
Building.
HMS Victory.....
Bismark.........
#90 Posted : 09 May 2019 19:56:50
Very nice and tidy work. Coming together very nicely.
Ant62
#91 Posted : 10 May 2019 15:02:10
Ive hit upon something that maybe nothing it concerns my build and part 31/32..
Watching the videos through out and reading the online mags ive noticed several differences between my build and the official build and other people..
As you increase the planking up the ribs and you get higher and higher then onto the gallery and the forward section of planking.
Now the forward section ive noticed that people have two planks in height to the rib 12....
My build as one forward plank but with about 2mm to 4mm sticking up above the plank from the ribs..
Do i cut a piece to cover those ribs!
The middle of the ship it shows you on the video and in the book to place a strip of planking in the middle to cover showing ribs upto the top edge of the ribs..
Now if i did that strip it would come to the middle of the single plank along the forward section i mentioned above.
Again do i do as in the video in part 31/32 cut a length n trim!
Building.
HMS Victory.....
Bismark.........
Ant62
#92 Posted : 10 May 2019 15:19:33
Here are another two photos of the areas that i have marked..
Photos next reply
Building.
HMS Victory.....
Bismark.........
Ant62
#93 Posted : 10 May 2019 15:23:37
Building.
HMS Victory.....
Bismark.........
Ant62
#94 Posted : 10 May 2019 16:32:49
I have given it some thought and i will cut a tapered plank for the front on both sides..
And a trimmed plank for the middle for both sides..
Building.
HMS Victory.....
Bismark.........
Ant62
#95 Posted : 11 May 2019 09:53:32
Two of the latest pics.
Building.
HMS Victory.....
Bismark.........
Ant62
#96 Posted : 11 May 2019 13:02:50
Just the top canon ports to mark out and cut....
The stern gallery wings as I call them are all wrapped up....
Building.
HMS Victory.....
Bismark.........
#97 Posted : 13 May 2019 12:16:13
Looking good!
Ant62
#98 Posted : 13 May 2019 16:11:56
DaDokta wrote:
Looking good!
Ta Walter..
Started on the next level of canon ports yesterday..
Had an hr or two doing nothing so i thought why not an hr dont go anywhere on this build.....
Building.
HMS Victory.....
Bismark.........
Ant62
#99 Posted : 13 May 2019 17:51:44
Have to chk the other canon ports location before i can commence..
Getting there..
Building.
HMS Victory.....
Bismark.........
Ant62
#100 Posted : 14 May 2019 13:50:21
Thats one side of canon ports done...
Only 15 to go....
Building.
HMS Victory.....
Bismark.........
10 Pages «<34567>»
This page was generated in 0.291 seconds.
