 Rank: Pro Groups: Registered
Joined: 29/12/2018 Posts: 223 Points: 671 Location: Lancashire
Seeing that there isnt an diagram with the template copy how do you progress to build the gallery! I have looked at the online instructions and there isnt anything with regards to making one.. So how do you proceed..... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Build stage 24 shows the template on a 1:1 scale. You need to accurately trace the template onto some stiff card as outlined in post #6 here... https://forum.model-spac...aspx?g=posts&t=1095
Regards Alan
If the template is a jpeg they will not open..... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
If you are working from the PDF instructions then you will need to print off the template page on 1:1 scale (page 98 of this link) in order for you to be able trace onto some stiff card. https://www.model-space....e/download/file_id/422/
Regards Alan
Cheers. So if i print to A4 size it will be correct..... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Hi Ant, have sent you a PM....
 ta......... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
