Good evening from 'The Dockyard'. Just a short update this week due to the extended Easter weekend. This week I finished off the lower guard rails on the port side of the lower deck of the conning tower and then concentrated on adding the protective mesh to the lower half of the starboard side guard rails. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I stripped a very thin piece of electrical wire of it's insulation and then unwound each strand so that I could use each of these strands to wrap around the vertical guard rail supports. By twisting them so that they pulled the mesh in tight to the vertical supports and thus required no glue. Pretty fiddly work, but now I have a technique, I aim to complete the rest of the mesh by my next update. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Showing the mesh further along. I cut it as one long piece and trimmed it as necessary. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
From above showing the mesh attached to the starboard side. At this point I have yet to trim the twisted wire strands that hold the mesh to the vertical guard rail supports. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Well that's it for this week. Just a short update due to the long weekend. As I mentioned before, now I have a technique for fixing the mesh, which did take time to figure out, I hope to make better progress next week and complete the rest of the safety mesh. Thanks for looking in, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Great work Phil. I’m convinced you miniaturise yourself when building this kit. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Great work Phil. I’m convinced you miniaturise yourself when building this kit. Mark Hahah  You've sussed me out Mark!  Thanks for looking in mate! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Excellent idea for fitting the mesh Phil and I'm sure other modellers will adopt your method in some of their builds....  .. All looks superb and look forward to your next session..... Regards Alan
Great idea, excellent update!Greetings, Walter
Gandale wrote:Excellent idea for fitting the mesh Phil and I'm sure other modellers will adopt your method in some of their builds....  .. All looks superb and look forward to your next session..... Regards Alan Thank you Alan. You had me down as Walter, so changed your quote when replying! By twisting the wire strands over and over, they really pull the mesh in tight to the vertical guard rail supports. Not too tigh though, as the wire will eventually snap, as i found out when trying out this technique. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
DaDokta wrote:Great idea, excellent update! Thank you very much Walter!! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Sticky Wickett wrote:Gandale wrote:Excellent idea for fitting the mesh Phil and I'm sure other modellers will adopt your method in some of their builds....  .. All looks superb and look forward to your next session..... Regards Alan Thank you Alan. You had me down as Walter, so changed your quote when replying! By twisting the wire strands over and over, they really pull the mesh in tight to the vertical guard rail supports. Not too tigh though, as the wire will eventually snap, as i found out when trying out this technique. Regards, Phil W. Oops....  … Its an age thing....  .. Have edited to put to right... Regards Alan
 All looking good Phil and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Kev the Modeller wrote:Another excellent update Phil and some nice work on those railings and mesh. Glad that you found a method that works for the mesh attachment, always a very satisfying feeling when you overcome a problem in modelmaking.
Well done!
Kev  Thank you Kev! Yes, i'm happy with the look and also the method now and you're right, it is satisfying when you hit upon a solution. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
arpurchase wrote: All looking good Phil and nice work Thank you very much Andy. Appreciated! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good morning from 'The Dockyard'. Another quick update this week as I have a long weekend booked and i'm off camping! Could do with being a tad warmer, but there you go! lol Anyway, I managed to finish the rest of the mesh on the bottom half of the lower deck guard rails. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
All the wire strands have been trimmed and their ends folded in. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Port side. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
From another angle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (5)
