I then continued adding the rest of the supports around the perimeter of the lower deck. The attached photo shows the next two supports fixed in place. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The guard rail is split in two; upper and lower halves. I decided to build up the lower half first as this section will also have gauze attached. The attached photo shows the 0.8mm diameter brass tube cut into 10mm lengths that will make up the vertical rails for the lower section. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Three of the vertical guard rails temporarily fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
To make up the horizontal rails i used Albion Alloys 'Connecto' which is bought in pack form and contains PE of different shapes. Each 'leg' of these shapes slides into the corresponding brass tube; in this case the 0.8mm diameter tube has an internal diameter of 0.6mm and the PE shapes have a width of 0.6mm. You can buy differing sizes that fit into the corresponding brass tube and all sorts of shapes can be made up using this clever product. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
This photo shows one of the PE shapes. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
By carefully bending the brass tube using brass rod slid inside to prevent crimping, i formed the correct curve and cut it into two lengths. I then attached theses two horizontal guard rails to the vertical ones. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Lovely work as usual Phil. Mark Regards Markwarren (Mark) Admin
From another angle. I'm pretty pleased with the way it's gone so far, albeit fiddly, which is good as making the guard rails for the lower deck and upper deck will take awhile! Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That's it for this week. Thanks for looking in, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Markwarren wrote:Lovely work as usual Phil. Mark Thank you Mark!  Making these guard rails will take awhile, so bear with! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Stunning as always Phil, lots of great tips being shown on scratch building techniques.... Very well done.... Regards Alan
Gandale wrote:Stunning as always Phil, lots of great tips being shown on scratch building techniques.... Very well done.... Regards Alan Thank you Alan!  Stay tuned for more guard rail adventures next week! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Phil That albion alloys connector set looks very useful. Seen it on their site but this is the first i have seen with it being used. Gives a very neat finish to your guard rails. But most of all impressed with your tube bending skills - must be taking some skill to get all those curves on the rails just how you want. Hope it continues well. Tony Happy Modelling
 All looking good Phil and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Top job as always Phil, with more great scratchbuilding, well done.
Kev  Per Ardua Ad Astra
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Hi Phil, Great update as usual!!! Thanks as well for all the tips & techniques. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
 looking good Phil Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Another great update!Greetings, Walter
birdaj2 wrote:Phil
Tony Thank you Tony!  Regarding the tube bending, I make sure I have a small diameter brass rod that matches the internal diameter of the brass tube i'm bending to prevent crimping. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
arpurchase wrote: All looking good Phil and nice work Thank you very much Andy! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
