4 Pages «<234
Graham's Easy Rider Build Options
bugsec
#61 Posted : 16 March 2019 18:19:07
Build Stage 23 - The engine assembly
Parts required:
A from Parts 24, B from Parts 25.
Also required:
Transmission case from Stage 22.
The transmission case and crankcase are fitted together and secured with screws.
bugsec attached the following image(s):
bugsec
#62 Posted : 16 March 2019 18:20:07
Build Stage 24 - The oil filter
Parts required:
B and C from Parts 26.
Also required:
The oil filter and oil filter top are fitted together.
bugsec
#63 Posted : 16 March 2019 18:21:08
Build Stage 25 - Fitting the oil filter
Parts required:
A from Parts 26.
Also required:
Engine assembly from Stage 23 and oil filter from Stage 24.
The oil filter is attached to the engine assembly and secured with screws.
bugsec
#64 Posted : 16 March 2019 18:21:36
Build Stage 26 - The distributor
Parts required:
Parts C, D and E from Parts 27.
Also required:
Engine assembly from Stage 25.
The gasket is fitted to the engine assembly. The distributor and distributor base are fitted together. The distributor is attached to the gasket.
bugsec
#65 Posted : 16 March 2019 18:23:10
Build Stage 27 - The transmission cover
Parts required:
A and B from Parts 27.
Also required:
The engine assembly from Stage 26.
The transmission cover is attached to the transmission case and secured with screws.
All unused parts from the pack are stored for later use.
#66 Posted : 16 March 2019 21:56:12
Nice work Grahame.Love
bugsec
#67 Posted : 12 April 2019 20:52:04
Thanks Mark
Pack 06 contains Parts 28 - 33 (Build Stages 28 - 31)
Parts supplied:
Parts 28:
A - Cylinder base 2
B - Cylinder
C - Bolts
Parts 29:
A - Cylinder
B - Cylinder base 1
C - Bolts
Parts 30:
A - Rear tyre
Parts 31:
A - Pushrod 3 + 4
B - Pushrod base
C - Screws
Parts 32:
A - Valve cover
B - Oil filter top
C - Oil filter
Parts 33:
A - Cylinder head top
B - Cylinder head
C - Screws
bugsec
#68 Posted : 12 April 2019 20:53:28
Build Stage 28 - The forward cylinder base
Parts required:
A and C from Parts 28
Also required:
The engine assembly from Stage 27
The cylinder base is aligned with the opening in the engine marked 2 and is then secured using 4 bolts.
bugsec
#69 Posted : 12 April 2019 20:54:27
Build Stage 29 - The rear cylinder base
Parts required:
B and C from Parts 29
Also required:
The engine assembly from Stage 28
The cylinder base is aligned with the opening in the engine marked 1 and is then secured using 4 bolts.
bugsec
#70 Posted : 12 April 2019 20:55:11
Build Stage 30 - The forward pushrods
Parts required:
A, B and C (Phillips screws) from Parts 31
Also required:
The pushrods are marked 3 and 4 and each is aligned to the respective mount on the base and secured with a screw.
bugsec
#71 Posted : 12 April 2019 20:55:56
Build Stage 31 - Fitting the pushrods
Parts required:
C (slot-head screws) from Parts 31
Also required:
The engine assembly from Stage 29 and the forward pushrod assembly from Stage 30.
The forward pushrod assembly is attached to the engine assembly and secured using the screws.
#72 Posted : 12 April 2019 23:08:58
That looks very nice Graham.
I took on the harley when it was in the sale.
Never built a bike before. Bit slow going at the moment in terms of build but looks like it will turn out a nice model.
Looking at your build here is that an infra red receiver that you have fitted into the horn part?
This one also looks a very nice model.
#73 Posted : 14 April 2019 09:36:55
Nicely done, looking excellent. It is a great kit and a great size. I bought the fat boy Harley helmet so it can be painted into the Captain America helmet, should have it finished soon. Just finalising painting it with the top coat of lacquer, I have also redone the tank to match.
Great workLove
#74 Posted : 14 April 2019 10:55:59
Nice job Graham, very neatly assembled and looking good. Well done. ThumpUp
4 Pages «<234
