benni Options
benni
#1 Posted : 08 April 2019 14:48:26
Rank: Amateur Level 1
My build diary update: I continue with the basic frame and suspension, wishbones in black.BigGrin
Then the side member added.
Next the shocks and disc brakes. These I decided to modify as I own a TWR Celebration coupe XJR-s (No 92), and this has uprated Bilstein shocks, so I thought I am already modifying the build so let's do this and add a bit of colour to my model.
Then the header tank and fan.
Next the steering rack and linkage added. You might notice I have decided to go with aluminium wishbones, as I noticed these on a number of reference pics I have.
Then the engine was laid into the frame, and the radiator added.
This was slightly modified by adding some alumnium netting which is visible from the back.
benni attached the following image(s):
Built: HMS Victory
