A striking resemblance to Hachette's Bismarck! Options
Trawler
#1 Posted : 13 May 2010 13:18:55
Rank: Amateur level 2
http://cgi.ebay.co.uk/BI...amp;hash=item3cabeecbfb
And here's low down of the original kit spec from Aeronaut
http://www.aero-naut.de/...p-models/war-ships.html
Looks to me like Amati copied the Aeronaut design!
#2 Posted : 04 August 2011 15:28:03
Hi trawler
Hatchetts version of the bismarck has a fully planked wooden hull. The super structure is made of wood then overlaid with brass plates to give details . Very good part work I am currently up to issue 138 out of 140 of this build also made it radio controlled.
Ian
#3 Posted : 04 August 2011 17:25:10
Ian sounds great any Photos,? you could put the build on the forum under OTHER SHIPSCool
#4 Posted : 04 August 2011 19:11:48
i will take some pictures and post on site Ian
#5 Posted : 04 August 2011 20:10:00
Good stuffThumpUp
#6 Posted : 04 August 2011 21:15:36
have just put a few photo`s in other sip builds to give you an idea.
i will take some better ones when finished Ian.
Under hatchets build the Bismarck
#7 Posted : 04 August 2011 22:46:19
Thank you Ian, for sharing this with us!!!BigGrin
#8 Posted : 04 August 2011 23:00:07
Thank You for looking MWG ian
