Thank you Andy! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Markwarren wrote:Excellent work as usual Phil Mark Thank you Mark! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Some more fine detail being added here Phil, those guns are looking good and will certainly come to life when the paint is applied, well done.
Kev  Per Ardua Ad Astra
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Hi Phil, Great update again. Those guns look amazing!!! Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Kev the Modeller wrote:Some more fine detail being added here Phil, those guns are looking good and will certainly come to life when the paint is applied, well done.
Kev  Thank you very much Kev. Hopefully not too long now before they get painted! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Garth wrote:Hi Phil, Great update again. Those guns look amazing!!! Kind regards, Garth Thank you very much Garth! Appreciated. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good evening from 'The Dockyard'. This week continues with the building and modifying of the 2.0cm Flak 38 double barrelled guns that will locate on the top deck of the conning tower. The next step was to make the gun operators handles. Using 0.8mm diameter plastic rod, I bent each piece around a needle file before clamping it to the file and immersing in hot water to form the shape. The attached photo shows the completed handles fixed to the guns with the 3D printed original next to them. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then added more detail using 1.0mm diameter brass rod to simulate levers. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next step was the tricky part; fixing the a-frames that support the guns onto their mounts.  Using plastic rod and 0.5mm diameter brass rod to act as securing pins, i finally got the guns mounted, hinges working. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looking from a different angle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
From above. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this weeks post. One more evening next week will see these guns completed and then it's onto the guard rails! Thanks for looking in, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Incredible as always! Those guns look so good!Greetings, Walter
Thank you very much Gray!  Two weeks of fiddly work plus one more evening next week will see these guns complete! Orders?!!!! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Very impressive work, loving it.... Regards Alan
Gandale wrote:Very impressive work, loving it.... Regards Alan Thanks very mcuh Alan! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good evening from 'The Dockyard'. This weeks update sees the completion of the two 2.0cm, double-barrelled Flak 38 guns for the upper deck of the conning tower and making a start on the guard rails for the lower deck. The attached photo shows the completed guns; handwheels and counter weights attached. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Next up; the guard rails! I started by making 17 guard rail supports. The guard rails slot into these supports and are positioned around the perimeter of the lower deck. I began by drilling out 1.5mm x 1.0mm strip with a 0.8mm diameter drill to accept the brass tube that will make up the guard rails. 17 holes in total. I then cut each side of the holes and filed these to clean them up. To prevent the brass tube from sliding all the way through, i then glued each individual square to a 1.5mm x 1.5mm strip and then filed and cleaned up each piece. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The first guard rail support fixed in place. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (10)
