More Head Issues Options
NeoFuture
#1 Posted : 21 March 2019 10:24:52
Rank: Beginner Level 3
Hi
I have another issue now, the head rotates one way then rotates the other and hits the buffer and the sensor is not stopping it. its rotating at the correct speed now, so im wondering if the cable from the MCU to the head is faulty, i have done the following
Head spinning too fast
Replaced MCU - head still spinning too fast
Replaced dome motor - head spins at correct speed, but does on stop on second sensor.
Tested both sensors - both work.
Changed MCU for another one, checked all connections, still the same, changed the cables on both sensors still the same
Can anyone shed any light on the issue, or suggest any fixes, i have checked all connections are tight and fitted properly.
NeoFuture
#2 Posted : 24 March 2019 18:46:49
Hi could I get some help from an admin on this issue please
NeoFuture
#3 Posted : 01 April 2019 16:58:57
Hi could i get an admins assistance on this please, as it currently stands as a £900 item that doesnt work.
NeoFuture
#4 Posted : 05 April 2019 15:33:46
Could i get some assistance on my issue please
Moderator
#5 Posted : 05 April 2019 20:07:51
Groups: Forum Support USA, Moderator
Hi Neofuture. Your request is noted. Your issue(s) are being referred to the appropriate sources to get some technical input.
NeoFuture
#6 Posted : 15 April 2019 14:01:59
Thank you, im still awating some one to come back to me ?
Moderator
#7 Posted : 15 April 2019 18:20:51
Hi NeoFuture. Your query is with the Project Team now. Hope to get back to you soon.
NeoFuture
#8 Posted : 29 April 2019 14:48:53
Please could you give me details of who to contact about this issue its now the 29th April and this model was supposed to be finished in December 2018
Moderator
#9 Posted : 29 April 2019 17:19:58
Hi NeoFuture. Sorry for the wait. The Project Team has responded. Please look in your inbox for a PM.
This page was generated in 0.089 seconds.
