4 Pages <1234>
FightingWillie Build Options
#41 Posted : 20 March 2019 09:49:27
This looks like a lot of sanding ahead!
#42 Posted : 20 March 2019 10:30:33
Looking excellent, that will rub down very nicely.
#43 Posted : 21 March 2019 09:31:51
Making good progress Mark, look forward to seeing how she looks after the sanding is done.... hope you have a good strong sanding arm....BigGrin BigGrin Cool Cool
FightingWillie
#44 Posted : 31 March 2019 20:26:30
Rank: Amateur Level 1
WOW that was a lot of filling and sanding. I lost a lot of the planking definition in the lower hull but i did not have much choice. It is not as good as the other builds I have been following. I hoping for what you call a 5-10 it looks great from 5 to 10 feet away..BigGrin
FightingWillie attached the following image(s):
z8000783
#45 Posted : 01 April 2019 06:44:05
Groups: Unapproved
Looks pretty good from here. Well done.
#46 Posted : 03 April 2019 14:11:22
Planking looking good. Well done.
#47 Posted : 04 April 2019 09:11:20
Nice update!
#48 Posted : 04 April 2019 10:48:08
Good steady progress....Cool Cool
leedsfromsouth
#49 Posted : 04 April 2019 18:38:53
Looking good ,we’ll done.
FightingWillie
#50 Posted : 03 May 2019 21:04:46
The latest update on the HMS Victory completed stage 44. I have gotten the rear gallery , wales , stem supports head deck and cut out in the wales so I can install the decorative pieces later .
I am going to stop here to copper plate the hull and I have a few questions. I have seen video showing people using CA glue but I have read that I should use contact cement, which is better? CA is straight forward, but contact cement I have never used before. My biggest concerns with contact cement is do you have to remove old contact cement before you start a new build session on the model and the tiles that you have already coated with cement?
#51 Posted : 04 May 2019 08:12:22
You have moved on very well with this one.
Its really looking the part.
When i ever get to doing mine i will be using one of the "flexible" superglues.
Contact adhesive depending on what you buy can be awkward as it has a tendancy to string when being used.
You can get non stringing gel versions and here is an ebay item code that might be of interest
271816733975. Code for a point of interest and not an endorsement of the seller by the way.
If you look up non dtring contact adhesive there are a number of brands but some come in tins that would last a lifetime and beyond.
I am sure you will get some other views on what people have used but for me it will be the superglue route as that seems a little more previse to me.
#52 Posted : 04 May 2019 08:27:40
Looking very nice, excellent work.Love
FightingWillie
#53 Posted : 04 November 2019 16:17:20
It has been a while since I updated my build. I have working on the copper tile on and off all summer. It looking OK, but gluing those tile on was tedious and the glue made mess Angry . Although now I am on to stage 45 and I get to touch wood again Laugh
FightingWillie
#54 Posted : 23 March 2020 18:39:10
I have not posted in awhile, it look like I missed posting some pictures
FightingWillie
#55 Posted : 23 March 2020 18:40:19
Here are some latest pic of my ship HMS Victory I have reached the half way point. So it is time to put the hull under raps and start to work on the mast and yards arms.
goddo
#56 Posted : 23 March 2020 19:27:06
Neat and tidy work there.
Very well done.
#57 Posted : 24 March 2020 01:23:17
Continue like this and you'll end up with one beautiful build, one you can display with pride..... looking great.....Drool Drool
FightingWillie
#58 Posted : 02 May 2020 21:44:06
Here is an update , I have completed the main and fore mast. I am going to jump around a bit and not follow the instructions. I want to complete the mizzen mast and all the yards before going back to the hull. I don't quite like the way the wales came out around were the wiggles will be installed.
CAThompson
#59 Posted : 04 May 2020 00:46:41
That is looking good!
Christopher
Current builds:
HMS Victory
Black Pearl
Builds on hold:
Millennum Falcon
USS Constellation
Future Builds:
Hanse Kogge (14th C)
Mary Rose (16th C)
#60 Posted : 07 May 2020 20:08:11
Looking goog BigGrin
You really appreciate the size of the Model once you start fitting the masts.
I also made the masts, yards & bowsprit at the same time.
4 Pages <1234>
This page was generated in 0.252 seconds.
