 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
Hello there about what stage do I copper the bottom thank you Ronald
Joined: 13/02/2011 Posts: 2,239 Points: 6,837 Location: East Sussex
Hi Ronald, When you have completed the hull,it may be best to order the copper plates as soon as possible so you have them ready, and have a pair of tweezers and glue to. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
thanks Trev I already have the copper tiles and tweezers, what glue do I use if it is a special glue where can I get it, super glue which I have but not recommended read, when do I tile the bottom though after the bottom is finished ? Ronald
You can start the tilling after issue 39 or 40. Use a contact adhesive.
ok thanks contact cement for the tiles and start around stage 39 or 40
