2 Pages <12
Lego Mercedes - Benz Arocs 3245 Options
#21 Posted : 08 March 2019 23:00:09
Thanks guysBigGrin
#22 Posted : 08 March 2019 23:15:06
Stage 22-30, more parts added to support the battery and cab, engine bearers and chassis.
#23 Posted : 08 March 2019 23:18:41
Stages 31-46, first parts of the steering and front suspension are added.
#24 Posted : 08 March 2019 23:25:18
Stages 47-62,with these parts the rest of the front suspension is assembled together with the battery mount and steering components.
#25 Posted : 08 March 2019 23:33:03
Stages 63-69, this is where the overall length increases with the construction and addition of the adjustable support legs which are controlled by the pneumatics.The orange beacons are also added at this stage.
#26 Posted : 08 March 2019 23:39:05
Stage 70-83,a lot of these parts are used for extending the chassis further and also the addition of the rear suspension and tipper mechanism.
#27 Posted : 09 March 2019 22:13:20
Stage 84-92, the parts in these stages are used to make up the mudguards and the fitting of the wheels.
#28 Posted : 09 March 2019 22:16:27
Stage 93-95, the crane and its pneumatics are assembled at this point and then fitted to the chassis.
#29 Posted : 09 March 2019 22:20:10
Stage 96-98,The battery pack is now fitted and once the front bumper assembly is built, it can be mounted at the chassis front.
#30 Posted : 10 March 2019 02:11:08
BigGrin Thats looking like a proper beast nowCool
#31 Posted : 10 March 2019 20:30:01
Thanks Andy.
Stage 99-102, in these stages the cab subframe is made and then the cab seats and dashboard are assembled and fitted to it.The steering wheel is added and then both doors are made and fitted followed by the rest of the cab body. this is then attached to the main chassis.
#32 Posted : 10 March 2019 20:44:29
Stage 103-105 These are the final stages of the build and mainly cover the construction of the tipper and its fitting onto the main chassis.All the systems were tested and found to work as they should.I will put some more pics in the finished build gallery[link below] showing some of the various positions.
https://forum.model-spac...spx?g=posts&t=31547
#33 Posted : 13 March 2019 11:36:07
This looks brilliant!Love
2 Pages <12
