10 Pages <12345>»
Karl's build of Panart's Amerigo Vespucci. Options
#41 Posted : 01 August 2011 11:56:54
Very interesting Karl mate,!!!!!!!!! Tell me more?Huh Blink
jeff averre
#42 Posted : 01 August 2011 15:14:59
How did I miss this one Karl, I've been drooling over this kit for monthsDrool and here you are cracking on with it, I'm just waiting for my 'Lotto' numbers to come up Laugh (must be my turn soon) then I'll bang my order in!
I'll be following your build with great interest, and I must admit that I was very suprised to see 'balsa' as the hull planking medium, you will have to be very carefull with with that to avoid damage, I hope you put the vineer on as I'm sure you'll get a better finish and it will be much stronger. (is there enough strip in the kit to do that?)
Keep up the good work Karl (whoever you are!!!Confused Blink )
Jeff
#43 Posted : 01 August 2011 16:01:30
Hey Karl I have just been looking at this Kit on CMB web site it is awesome!!!!! mate, keep the photos comingBigGrin
jonny7england
#44 Posted : 01 August 2011 16:34:11
Wow Karl...you are really cracking on with your build mate,,,,fantastic!!! ThumpUp
#45 Posted : 01 August 2011 17:09:29
Jeff
hi jeff and the rest of you kind gentlemen,there are two ways of planking this model,the first is to balsa plank,then cover with dope tissue,after a coat of diluted aliphatic glue,then primed and rubbed down and srayed paint.the second is to do all the above then before priming put 2nd planking(veneer) then prime and paint.not decided yet which way to go.
#46 Posted : 02 August 2011 22:24:36
BigGrin Hi karl just an idea from my model aircraft days another way is to use nylon instead of paper as it will give more strength across the balsa
#47 Posted : 02 August 2011 23:59:52
hi andy,yes I had thought of using several different medium's including silk.fibre glass,and even carbon fibre,what I wanted was a normal model,that was reasonable enough to build fairly easily,not a tank busting bullitproof boat that would stop a torpedo in it's tracks,
so I going for a second layer which is supplied and is .8mm.x6mm basswood,which will strengthen up nicly,will put up some pics tomorrow.
and thanks for the idea,all comments welcome.
jonny7england
#48 Posted : 03 August 2011 10:22:18
Hi Karl...did the balsa come with the kit or was it your idea to use it as a different medium for planking?? I like the idea very much, and the idea varying materials as a stengthener? I'm very impressed mate...very impressed in deed!!
Drool
P.S...how's the non smoking coming along???
Blink
#49 Posted : 03 August 2011 11:40:39
hi john,non-smoking still on,just,as the balsa and basswood both are supplied,along with tissue(modelspan)so not really my idea,but this is the way I chose,seemed more of a regular way to go.
Mike Turpin
#50 Posted : 03 August 2011 12:50:37
Hi Karl
Would the reason for using the tissue and dope method be to create an overall smooth surface which is what the hull of a relatively modern steel hulled ship would have? If you create a planked surface it will be less authentic?
Just trying to understand these methods of construction.
Mike T
IAN
#51 Posted : 03 August 2011 13:33:18
Hi Karl..
Look forward to seeing your method of build to add more knowledge to this interesting hobby.
Best regards,
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
#52 Posted : 03 August 2011 13:49:27
hi mike and Ian,yes mike the tissue/dope is to have a smooth finish,but put onto the balsa it would susceptible to dents and digs,so I will sand seal and rub down several times and then tissue with further rub downs to get the smooth surface.
#53 Posted : 03 August 2011 18:06:59
Hi Karl the nylon i was talkin about is very light 1 oz per sq/m,LOL so it will give strength but not make it torpedo proofBigGrin It will also dry more opaque than tisue so easyer to see whats underneath
#54 Posted : 05 August 2011 17:42:09
that's the 2nd.layer of planking,.8mm.x6mm.
#55 Posted : 05 August 2011 17:43:11
#56 Posted : 07 August 2011 11:03:35
here is some info on the ship.
http://www.admiraltyship...Vespucci_Ship_Model.html
jonny7england
#57 Posted : 07 August 2011 11:23:50
The hull is looking absolutely amazing Karl...Brilliant mate...ThumpUp
#58 Posted : 07 August 2011 11:46:26
Awesome build mateBigGrin
#59 Posted : 07 August 2011 12:08:33
BigGrin Lookin sweet so far karl, a very nice finish on your planking
#60 Posted : 07 August 2011 14:15:51
the decks are now planked with 3mm.x.05mm walnut.
10 Pages <12345>»
This page was generated in 0.243 seconds.
